a different take on a Natural Edge Bowl
charlie belden
I was given this rather large chunk of old dry weathered and charred, partially moss covered, redwood. One face was the outside of the tree and from its curvature have worked out that the trunk from where this chunk came was about 86" in diameter. It had some dry rot in a lower corner which I dug out some of to see how far the rot had gotten. Having partially hollowed out the some of the bottom, it got me thinking . . .
What If . . .
I hollowed out a space underneath
and
carved a hemispherical depression in the top
and
put a 5 gallon bucket in the hollow inside
and
put a little recirculating pump in the bucket
and drilled some holes from above into the space underneath
and
ran some clear vinyl tubing from the "bowl" to the pump and back?
Given the size - and weight of this chunk of wood, turning the bowl depression and the bottom hollowing were out of the question.
BUT
You CAN carve out wood - with a chainsaw.
The shallow bowl depression in the top was easy.
Hollowing out the underside to accomodate a 5 gallon bucket - was NOT.
Chainsaws are great for cross cutting and ripping. But plunge cuts - 13" deep - with a 16" bar? THAT is asking for a kickback. And if you think a kickback on a table saw is dangerous, imagine it's not a piece of wood being kicked back - but a running chainsaw coming at you . . .
Did a LOT of "nibbling away" with the bottom part of the tip of the bar and have another 2" to go.
When done I'll have a very different take on a Natural Edge Bowl - with moss growing on it. The recirculating water will keep the bowl full - and the adjacent moss damp and green - a nice Zen-ish fountain for a back corner of my little japanese garden
Re: a different take on a Natural Edge Bowl
Charlie My friend does plunge cuts like that all the time when he's carving his large vessels. I have done the same thing when cutting notches out of a tree when felling. It does take some control but I haven't found it that dangerous. Start with what would be the heel of blade. I'm really not sure how to describe the cut. I will have to pull out the saw and do one this afternoon if it quits raining. Then maybe I can describe it.
Don Leydens
Don Leydens
Excellent idea, Charlie!! Love it. Look forward to the finished photos.
Mike Foster
John is right. Actually a plunge cut is pretty safe because the wood prevents the bar from kicking back. A plunge cut is a standard cut taught by The Game of Logging folks (very safety conscious ) for felling trees.
END GRAIN Plunge, Not SIDE GRAIN Plunge
charlie belden
As is often the case, too little information can lead to miscommunication. So let me fill in some info I didn't specify originally. I'm playing with an outside chunk of what was orignally an over 7' diameter log.
The top of the DRY chunk is covered in live moss. Three of the sides have some moss growing on them mainly up near the top.
I want to save as much of the moss as I can.
I've chainsawn in a hemishperical depression in the top of the chunk of wood, disturbing as little of the moss as I could.
The bottom third of the "lower left corner" had dry rot - which I've dug out.
I want to hollow out a space large enough to fit a 5 gallon bucket in (BLUE - ie about 12" in diameter and about 13" deep.
I'm using a chainsaw with a 16" bar to do the hollowing and am about 11" into the hollowing depth. I'm basically doing plunge cuts - init END GRAIN - using the lower half of the nose of the bar to sweep, in side to side arc, into the bottom of the wood - the END GRAIN.
Begining the hollowing this way I had room to angle the chainsaw quite a bit, keeping the teeth on the upper half of the bar away from the cut. But as I go deeper, there's less and less room to angle the bar and the teeth on the top of the bar - the ones that will cause "kickback" - are getting closer and closer to contacting the wood.
So, before any reading this thread, who is new to chainsaws and chainsawing, gets the impression that it's safe to plunge the tip of the chainsaw bar straight into a piece of wood - into side grain or end grain - further discussion and caveats are probably warranted.
Re: END GRAIN Plunge, Not SIDE GRAIN Plunge
Mike Foster
Charlie,
I didn't read your first post as carefully as I should have or I would have picked up on that. An end grain plunge is certainly not the same as side grain, but once the tip is into the wood, I would assume you would be safe. Problem is that you are still cutting into end grain, which doesn't cut well no matter what. I don't have any experience with that type of cut. Bet you could find some information on chainsaw carving sites though.
Steven Antonucci
Safe to do if you are good with a chainsaw *LINK*
steven antonucci
Look at Liam O'Neill's site to see how to do it. He's working 9' long sections of redwood.
Steve
Liam O'neill
Rodney
"I want to save as much of the moss as I can."
Charlie,
You can probably take bits of the moss that are coming off and chop them up and mix with water (rain water not city water that likely has addition of chlorine) to make a thick pasty mixture and spread that on places of the wood where you want to encourage moss. If you keep it moist it can establish itself faster that way than letting what is already there spread on its own. I assume you have it in a partially shaded part of your garden and I think it would look very nice.
Many of the modern non-pro model chainsaws have anti-kickback chains that would interfere with your method but I agree, a plunge cut can be made safely by someone who is aware and working carefully and the pros even sometimes use them to fall trees when trying to avoid the "barber chair" effect. A soft wood like you used would be fairly easy to plunge cut.
Re: Safe to do if you are good with a chainsaw
charlie belden
Could you provide the link to the page on his site that shows his use of a chainsaw?
charlie belden
For some kinds of moss, the ones that stay low, blending some of it with yogurt and some Miaracle Gro works.
But the moss on this piece look like small, delicate ferns 1/4" to almost an inch tall.
Have the hollowing in the underside done.
The other "challenge" was finding a 7/8" drill bit that was long enough to bore a hole from the top down into the cavity the bucket is in - for the water inlet tube. The tree trimmer who gave me this piece of wood loaned me one that's 20" long. Took a while to bore the hole with one of my cordless drills. Should've spend the time looking for my larger plug in drill.
Now I need to decide if I should epoxy the bottom of the bowl on top, fiberglass it or just leave it alone. It's end grain so it'll soak up a lot of water. Maybe a lot of coats of 3 lb cut shellac will seal things.
Steven Antonucci
Try this
steven antonucci
He demoed this via slides to our club. I have done something similar with a gas saw in my shop, and the only thing preventing me from doing more of it is the stench of chainsaw fumes that lingered for days. You need an electric saw to do this indoors.
http://www.liamoneill.com/workshop/index.html#Chainsaw_Demo_Gallery
Steve
Steven Antonucci
P.S.  The lathe is not running!
steven antonucci
The saw runs, but the lathe is manually rotated by hand into the cut a half inch or so at a time. The saw is mounted on a tool stand and everything operates completely safely as long as you don't try to clear shavings with the chainsaw running...
Steve
P.S. I plunged my Stihl in at an angle and took out a cone, and then just cut the rest out by eye once the middle was gone.
