OT Gallexy III
Terry Quiram
Is tere a way to turn off auto correct when sending text msgs? That is so frustrating. Especially when "shake out the pages" translates to "shave the cat out".
OT Gallexy III
Terry Quiram
Re: OT Gallexy III
Don in Central Illinois
O, go ahead and shave the cat. Remember these are smart phones, and maybe they're trying to tell you something.
Re: OT Gallexy III
Dale Bright
Yes, go to Settings, Language and Keyboard and you will find the settings for the keyboard. I have the II and that is what worked for me.
Dale
Re: OT Gallexy III
Mark Wollschlager
Go to the Settings page
Choose Language and Input
You should see Samsung Keyboard as the default ( perhaps )
Look below and see Samsung Keyboard below that with a gear to the right
Tap the gear
You will see a setting for Predictive Text which is probably On, Tap On and it should switch to Off.
Use the back arrow at the top to return to the settings page.
That should turn off auto correct for all apps.
Hope this helps.
Mark
Thanks. That did the trick!
Re: OT Gallexy III
Josh Bowman
The question is, can you shave a cat on the lathe? How do you chuck them up or should you do it between centers?
