ADVERTISE HERE - FREE TRIAL
Conical boxes and tapered edge lids
Craig Daymon
I have a box on the lathe that has a conical shape. My lid intention is to have a matching taper on the edge of the lid, which will sit down within the tapered opening. (Mom's Christmas gift.)
My thinking is that the taper will allow the lid to rise and fall slightly with wood movement, hopefully maintaining the same fit, snug and at the same time loose, based on gravity and the weight of the lid.
My concern is mostly to do with what finish will give me the least friction, as that is what I figure to be the biggest defect in this design.
Any suggestions/thoughts would be greatly appreciated. Any thing I'm not considering as well.
Thanks,
Craig
Re: Conical boxes and tapered edge lids
Just wax it after you finish it. Then the finish does not matter. The wax is slick enough too slide no matter what. If your into the Beal the last step of course is a wax so that will work.
Harry Robinette
Harry Robinette
Wax is great .If you want more protection I would rub in Arm-R-Seal by General Finish. It's oil and urethane mix and if rubbed in it looks like just a oil finish.
