ADVERTISE HERE - FREE TRIAL
3-sided wonder
3-sided wonder
3-sided wonder
Roger Chandler
I did my first 3 sided bowl a couple of days ago, and liked the result......thought I would do a variation on the theme..........this time with a pedestal and larger.......this is ambrosia maple and measures 6-1/2" wide and 4-5/8 tall.
Still have some buffing when the WOP cures and then another couple of light coats.
Re: 3-sided wonder
Re: 3-sided wonder
Philip Duffy
Very nice! I will be trying that one for sure. Philip
Re: 3-sided wonder
Re: 3-sided wonder
I like this one better. It has some of you in it. I like it when people add their own touch but it has to be done with all the elements working together and you did a good job.
Re: 3-sided wonder
Re: 3-sided wonder
Roger Chandler
Thank you, John.........appreciate your comment. Nice article on the gun lamp in the American Woodturner Magazine........very nice work indeed!
Re: 3-sided wonder
Question
Dustmaker Mike
Ok now I have something else to try. Did you start out with a triangle piece for this?
Re: 3-sided wonder
Re: Question
Roger Chandler
No Sir.......I started out with a cube.
Re: 3-sided wonder
OK now I feel stupid
Dustmaker Mike
I am not sure how that looks in my little pea brain. Would you by chance have a picture of the blank before turning it. It could give you a good reason to turn another one(-;
Thanks
Re: 3-sided wonder
Re: OK now I feel stupid
Don in Central Illinois
Look on youtube under Dob Voas. I'm working in my first three sided bowl, also. Couldn't get it in my mind until I saw the video.
Re: 3-sided wonder
Roger Chandler
Don Voas is a friend of mine and former president of our local AAW chapter....his demo on this a couple of years ago is on daily motion. You will see the orientation on his video.
Re: 3-sided wonder
David Walser
Mike,
The blank starts out as a cube. If you have a cube -- even a Rubick's Cube -- take it out and follow along. Set the cube on a flat surface in front of you. Now tilt the cube until on of the corners is pointing straight up and the corner opposite is resting on the flat surface. Put your index finger on the corner pointing straight up. You should be able to spin the cube on the axis that runs between the two corners (points) of the cube. Imagine your index finger is the headstock and the flat surface is the tail stock. This is how the blank will be oriented on the lathe.
Notice that when you spin the cube, three of the corners spin on a plane that is perpendicular to what would be the ways of the lathe. These corners will form the three points of the three sided bowl.
Make sense?
Re: 3-sided wonder
Yup it makes sence
Dustmaker Mike
I really think I understand. Wow scary
Thanks
Re: 3-sided wonder
very nice explain David
Re: 3-sided wonder
Dob Voas?
Jorge
I just did a search in youtube and came empty handed, but in the front page, who else? John Lucas! and the parting tool.
Re: 3-sided wonder
Thank you!
Re: 3-sided wonder
Re: Thank you!
Sorry, I can't type very well on thks Nook.
