Buckeye Goblet
Buckeye Goblet
Don Leydens
Buckeye Goblet
Don Leydens
This is a piece of Buckeye Burl with a dyed black walnut base. The goblet's dyes are black, green, yellow and a tad of golden orange. The inside is natural and the undercut rim was colored black with a marker so it wouldn't bleed. 1/16th thick and finished with tung oil and nervously Beall buffed.
Thanks for looking and all comments are welcome, Don
Re: Buckeye Goblet
Re: Buckeye Goblet
Carole Valentine
Gorgeous, Don! At 1/16", did any of the dye bleed through to the inside?
Re: Buckeye Goblet
Re: Buckeye Goblet
darrin hill
how'd u make it look metallic? or is that just the photograph?
Re: Buckeye Goblet
Don Leydens
Re: Buckeye Goblet
Don Leydens
Hi Carole! No, no bleed through. The dye only penetrates a very small amount and the alcohol based ones dry quite fast, maybe that helped. I was worried about messing up the rim, which is why I used a marker on that.
Thanks for asking, Don
Re: Buckeye Goblet
Don Leydens
Re: Buckeye Goblet
Don Leydens
Hi Darren! I guess it's the photo. I'm very color blind and don't see that at all, but others have said the same thing. Heck, as long as it looks OK, I'm fine with that :-)
Re: Buckeye Goblet
Re: Buckeye Goblet
Randy Gleckler
Very very nice looking Don, I love the color/look you got out of that, Very nice.
Re: Buckeye Goblet
Mike Stafford
Mighty pretty!
Re: Buckeye Goblet
Don Leydens
Dying process
Don Leydens
Thanks for the kind comments. Someone just emailed me and asked who the dying was done. Below is what I wrote him in case anyone else was wondering. Hey, if a color blind dude can do it, so can you!
I started with a finished piece sanded to 400. Then with the piece still on the lathe, I put on a layer of black alcohol based dye. I turn the piece by hand while applying the dye. Sanded it down (320) to where I liked the density of the color. This took a little while as the whole piece looks scary black when first applied but it comes off easy enough. Then the green went on the same way, sanded with 320 also. Then the yellow sanded with 400. Just a bit of sanding with this color, it doesn't need much. I added a bit of golden orange for the heck of it and sanded that very lightly also.
I only waited about ten minutes in between each layer, as they dry very fast. The whole goblet was then sanded with 0000 steel wool and about 8 coats of Tung Oil was applied and each was thoroughly wiped off and steel wooled before the next one. I let each coat sit overnight. When done, I let it cure for 5 days and then it was carefully Beall buffed. A hand rubbed wax like Renaissance Wax would work well also. That's how the inside was done.
Hope this helps and thanks for asking, Don
Thanks,
Don
Re: Buckeye Goblet
Wow!
Re: Buckeye Goblet
Pete G
Re: Buckeye Goblet
Pete G
A fabulous piece Don, great proportions & colouring.
Congratulations on the WOW cover of the day also well deserved with this one :)
Pete
Re: Buckeye Goblet
Re: Buckeye Goblet
Don in Central Illinois
Beautiful.
Re: Buckeye Goblet
Jim Barbour
Glorious proportions and I love the stem
Re: Buckeye Goblet
Bob Moffett
Re: Buckeye Goblet
Bob Moffett
This piece is fantastic. I'm beginning to wonder if you are really as color blind as you claim to be. I really like everything about this piece.
Re: Buckeye Goblet
Keith Tompkins
Re: Buckeye Goblet
Keith Tompkins
Hi Don, saw this on wow....Ya' done good! beautiful piece.
Re: Buckeye Goblet
Beautiful!
GaryG in MD
That's very nicely done, Don.
I love everything about it.
You nailed the shape, and the colors and finish sing. ...Gary
Re: Buckeye Goblet
Don Leydens
Re: Beautiful!
Don Leydens
Thanks for taking the time to comment. It's quite appreciated!
Re: Buckeye Goblet
Leo Cuellar
Stunning coloration...
Leo Cuellar
That is extremely beautiful, Don. The form looks great as well.
