Thinning down Elmer's glue
Dan Jechura
Has anyone done this? I am trying to stabilize a pithy spalted Ambrosia Maple bowl so I can finish turning it. I do not know how much water to add.
Dan J.
Dan Jechura
Dan J.
Re: Thinning down Elmer's glue
John Veerkamp
50-50 works for me.
Rob Wallace
I agree with John - certainly no LESS concentrated than a 50% dilution (glue:water = 1:1). I suggest trying the mixture on a non-critical wood sample first to be sure it hardens enough. I have also tested similar dilutions by applying some to a piece of glass and allowing it to dry completely. If the resulting glue film is rubbery, you may want to get fresh glue or use different water to dilute it. Polyvinyl acetate glues are normally pretty stable, but depending on the mineral content of the water used for dilution, the glue mixture might get gummy upon drying. If you have hard water, I might suggest using distilled water for such mixtures.
Good luck!
Rob Wallace
White glue
Jorge
Agree with the 50/50. White glue.
If I remember correctly the white glue works better then the yellow for this application. I have not used glue in a long time, now I use lacquer, also diluted something like 70% lacquer - 30% lacquer thinner. I use more or less thinner depending in how porous the wood is.
It goes right in and dries fast, you can turned next day. the glue takes longer to dry.
Dan Jechura
Well I have not bought the white glue yet so I think I am going to try the thinned down lacquer instead. I'll let you know how it turned out.
Thank you all for your help in this.
Dan J.
Dan I used thinned lacquer all the time. My dilution is probably about 70/30 also but it's not finicky. I find I can often turn out shallow defects in 10 or 15 minutes. Really deep punky hours take a 3 or 4 applications and I usually let that much dry overnight.
