Tilt away for PM3520B
George Taylor
Has Robust discontinued the manufacture of the Powermatic add-on? It is not on the price list or product list. You can still search and find the web page for it but it is not linked.
Thanks
George Taylor
Thanks
Ask Brent- a quick phone call would confirm
Re: Tilt away for PM3520B *LINK*
Cyril Griesbach
George, I have one of the prototypes that I tested for Brent. I googled "Robust Tilt-a-matic and got this link. I wouldn't be without it on my lathe.
http://www.turnrobust.com/Tilt-A-Matic_by_Robust.html
Nick Todd
I would follow through. The money I spent on the tilt away was the best woodturning money that I have spent.
Cyril Griesbach
Late this morning I got the following email from Brent English of Robust Tools
Hi Cyril,
Saw the discussion this morning on Wood Central. You can quote the following for me if you wish:
“Sorry but we did discontinue the Tilt-A-Matic for the PM 3520. We thought it would be a good seller based on early response from guys like Cyril, and the fact that we sell so many of our toolrests to Powermatic owners. Everybody that has one seems to love it. Unfortunately, sales just didn’t justify continuing to make it, inventory it and advertise it. This was a reluctant decision on our part.- Brent English, Robust Tools”
Sad news for Powermatic 3520B owners.
Cyril
Brent
George Taylor
Thanks Cyril, I really wanted to go with a Robust lathe for that feature amongst many others but just couldn't swing the cost with the adult son in assisted living. Then the PM discounted sale came out last week and we jumped on it. I guess I will look at the "Down & Out" from JT Tools. Does anyone use that?
Thanks for the feedback.
Mike Peace
You may want to check this one out.
http://www.jtturningtools.com/tailstockmanager
Scott Crumpton
I've got the "Down & Out" on my 3520B. Like it a lot.
I had to clip the corner off of the hinge plate so that it would clear the bed extension that's mounted low on the legs. JT provided instructions and may have modified current production so that this isn't an issue. You may also want to tie it back with a bungee cord when turning off the end of the lathe. If you have the bed extension mounted high you'll need to do some drilling and tapping on the extension to mount it.
Over all, it's a good product, a bit expensive.
---Scott.
Scott I'm not sure how you would use the tilt away with the bed extension mounted high. Can you describe. I haven't purchased any tilting tailstock accesories yet because I do plan to move my bed extension to the other end of the lathe and use it lowered sometimes and high others. Right now it's on the right hand end of the lathe and sits under the motor so it's more or less out of the way.
I have a 3520A so will have to modify it to move the bed extension down but it's necessary because I have a couple of projects that need the swing. However most of the time I would like it in the up position because I can just move the tailstock out and it's out of the way enough to not need to remove it.
Currently I'm still strong enough to move the tailstock off the bed by simply carrying it over to the workbench. However that day will come when I can't and will need a tilt away so I'm interested in how the tilt away would work with the bed extension up.
