Turning Corian
Turning Corian
Turning Corian
Don in Central Illinois
A gentleman at church offered some off cuts of Corian. Never turned any. Is it worth it?
Re: Turning Corian
Re: Turning Corian
Sure is. I've used it for inlay's in ornaments and turned finials from it. I've also used it to make some custom drives for my tailstock.
Re: Turning Corian
Re: Turning Corian
Tom Stevenson
I tried some Black Corian with metalic flecks in it. I turned a small bowl with spalted maple, including several worm holes. I epoxied the Corian to the edge. It came out great. Really striking with the pale maple, black spalting and shinny thin black rim. ----- Until the wood moved with seasonal movement. --- well it was spectalular. If you can somehow allow for wood movement, go for it. It turns easily and polishes up nice.
Re: Turning Corian
Re: Turning Corian
Roy Girolami------WebKitFormBoundary9yANUT8mn8C+Zo
I turned a pen or two out of some I got. Turns easily and polished up fine. Most I've seen is only 1/2" or so thick, so you are limited in what you can do with it.
Roy Girolami
Re: Turning Corian
Dennis in Southern Oregon
Re: Turning Corian
Don, I have used it many times in specialized applications. It turns easily, although slowly, with sharp tools, but I personally do not regard it as attractive as the primary material of a turning. First, it looks like plastic (not surprising) and second, it is very heavy. One of its desirable features is that is very strong, dimensionally stable, and can be threaded by taps and dies or by hand chasing. Thus it very useful for making threaded inserts for boxes, canisters or urns. What I find it exceptionally useful for is making fixtures of various sorts for the shop. Some examples: vari-grind-like sharpening jigs, sharpening holders for round skews, specialized face plates and the end plates and rings for for shop-made vacuum chucks. Just about anything of this sort that you might consider using plywood for can be better served using corian. It normally comes in half-inch thickness, but it can be laminated using epoxy to make thicker slabs as needed.
Dennis
Re: Turning Corian
Harry Robinette
Re: Turning Corian
Harry Robinette
It makes a great hand wheel for your lathe. I made the one on my General 18" bed lathe from it and love it.
Also have made allot of pens and finials.
Re: Turning Corian
Re: Turning Corian
Thanks all. Guess I'll stop by and pick up some and experiment.
Re: Turning Corian
Ric Taylor
Re: Turning Corian
Ric Taylor
Google Andy Chen Corian to see some beautiful large hollow forms turned entirely from Corian. Also search for him on the AAW website. Very thin walls (almost translucent) and very light weight. Fantastic pieces. Andy does demonstrations at major turning events around the country.
Ric
Re: Turning Corian
Joe Bradshaw
Re: Turning Corian
Joe Bradshaw
Don, it is great for making ladies bangles. glue several pieces together or add colored dot. ladies love them. Easy to turn with scrapers.
Re: Turning Corian
Re: Turning Corian
Michael Lane
While I haven't turned Corian I use it often for jigs. It slides better than plywood. I made a router sled for the lathe using it. The sled was first made from plywood and it was to hard to move. I also made an indexing bracket for the oneway to give me more indexing position options. It is a little brittle so I don't use it when there can be shock loads.
