Steady Rest
Mark Motquin
Has anyone used the AR-Liberty 20" 4 wheel steady rest ? What are your opinions of it.
Steady Rest
Mark Motquin
Re: Steady Rest
Joe Meirhaeghe
Can't speak about the Liberty. But I do have one from Advanced Lathe Tools LLC. made by Steve Sinner it's very heavy duty Steel. It has large industrial wheel bearings, & heavy duty wheels. Not the small skate board bearing & soft wheels most steady rest have. I've turned 300 to 400 plus lb. logs & used the steady when hollowing them. It's supported everything I've ever needed to turn.
I'd recommend it to anyone needing a heavy duty Steady Rest.
Look at the Adavanced Lathe tool steady rest.
Joe Meirhaeghe
Re: Steady Rest
Lyle Jamieson
I have experimented with many steady rests and made my own years ago before there were any on the market. Why do we need a steady rest?? Because we want to do big, heavy things. Heavy, big things need all the support you can get. I highly recommend the 4 wheel version. I have destroyed the wheels on the 3 wheeled versions.
Steady Rest No Need for 4 wheels.
Joe Meirhaeghe
3 Wheels are all that's need to support any size log your lathe can handle. The 4 wheel versions with 2 wheels on top do not offer any more support for heavy logs than a 3 wheel version. It's the bottom wheels that carry all the load. The upper wheels do not carry any of the weight of the log being turned.
If the wheels and bearing are heavy duty as used in the Advanced Lathe Tools Steady large heavy logs are no problem.
As I have said I have turned many large logs some up to over 450 lbs with the Advanced Lathe Tools Steady rest with no problems what so ever.
Re: Steady ... Top Wheel Loading
Doc Green
The top wheel, or wheels, have to withstand the force the tool exerts on the log in the process of doing the cutting. Action-reaction: the wood pushes down on the tool; the tool pushes up on the wood.
Therefore, although the top wheel(s) do not carry any of the weight of the log, it (or they) carry All the force the tool exerts on the wood. During a heavy cut or in the event of a catch, the load on the top wheel(s) is considerable.
I know of a well-known turner who got a catch and pulled a (really) large vase out of a shop-made, heavy duty, three-wheel steady. When it departed, the vase went UP. That turner now uses and recommends a four-wheel steady.
Lyle Jamieson
Thanks Doc, I discuss the fact I don’t use or want to use a steady rest in my September, 1012 newsletter. I will not reprint it here because it promotes my DVDs. I do not have a horse in this race, I don’t sell steady rests, and never will.
Let me explain in more detail the reason 4 is better then 3. Why do we use a steady rest?? Because we have vibration, that’s a given. What happens when there is vibration?? The wood moves back and forth on its axis. When the wood moves, it pushes against the steady rest. The rubber wheels give/ flex/ mush/ compress. As the wheels compress they push back, forcing the wood in the opposite direction compressing the wheels on the other side of the vessel. Those opposing wheels compress and push back again, and again, and again. A no ending set of vibrations......not good. So to minimize the vibration I choose to use 4 wheels. Its got to be better then 3. There is a huge support difference between 3 and 4.
But my first priority is to prevent the vibration before it starts and not need the steady rest in the first place. See my reprints of the newsletter on my web site if you want more of my rants.
Mark Motquin
Thanks guys for responding to my question, if I do decide to buy one it would be the 4 wheel design. I was hoping somebody would have used the liberty steady rest because that's the one I'm interested in buying. Thanks again
