Oil finish question?
Steven Antonucci
steven antonucci
First, aside from the oil turning into a gelatinous mess (curing), can oil (specifically Watco, but generally- any?) go bad?
I put a coat of Watco on a vessel I made last night. The vessel had been sprayed with some kind of varnish that I used as a sanding sealer. It was complete dry, and then sanded through flush to the surface. I put a thin coat of Watco over it, and it was still tacky this AM.
I don't use oil all that often, so am I just not waiting long enough, or is the oil bad?
Steve
Re: Oil finish question?
Dick Hines
Dick Hines
An oil finish needs to soak into the wood. The sanding sealer kept it form doing so. Next time just use the oil or sand the sanding sealer down to the bare wood.
Bill Jacksonville, NC
Take a look at Watco Danish Oil ingredients; 60% mineral spirits, 1% aromatic petroleum distillates, raw linseed oil, vegetable oil, and resin. Yes, product deteriorates with age and exposure to air. Not sure that is only problem you have. Suspect solvent ingredients softening varnish already applied.
Would have same problem if applied Watco first and did not let it dry thouroghly before applying varnish.
waltben
Think it was Wood Magazine that did a review & comparison of various oil finishes years ago. Back then I was using Minwax antique oil. They wrote that there was only two they'd classify as a wiping varnish or antique oil (there's no standard for what it's supposed to be), and Minwax was one of them. Watco's antique oil was the other, but they also listed what was in many of the common Danish oils (again, no real standard for what's in them). I don't recall what they said about Danish oils, but I know that the result of the entire article was my switching to tung oil as it's waterproof and food safe when cured.
Lyle Jamieson
Lyle Jamieson
Steve,
Ive been using Watco Danish for 40 +years. I have used it from an old can that has started to thicken with age with no problems on bare wood. It is a true wiping varnish so it takes a long time to cure...like a week, for the first coat. Once the first coat cures down weep in the fibers the next coatings can be in frequent intervals a day or two apart. The can says "ready to use in 8-10 hours". I would never buff or recoat that fast. The second coat will soften the first coat and it will take a month to cure deep into the wood.
Re: Temperature?
Steve Criscenzo
Steve
I have found that I sometimes have problems when my shop temperature gets cool. I have also found that I can sometimes get a sticky oil finish to set by placing it near a heater (or in the summer I just set it on the deck in the sun). I have saved many a finish by applying gentle heat.
Good luck
Steve
Did you wipe off the excess?
Don Orr
If you don't, it will stay tacky for a VERY long time. It build very slowly especially over a sealer. As Lyle said, it is it's own sealer but needs to cure a while before a second coat.
Danish Oil basics:
Apply liberally
Allow to soak in
Apply more
Allow to soak in again
Wipe off any excess
Allow to cure in a warm area
Dispose of oily rags properly
Add as many coats as desired in above fashion.
HTH
Steven Antonucci
Monday, 3:30 PM and still mildly tacky
steven antonucci
reminds me why I don't use oil finishes all that often... ugh!
Steve
