The Shape and Hollow Tool *LINK*
Mike Stafford
Mike Stafford
I came across this is my search of the internet. (I am getting close to the end as I have nearly viewed all the pages..... :b )
This Shape and Hollow Tool concept takes something that is similar to an Oland tool and mounts it in a unique captured holding system. The tool slides in and out of the holding system and the holding system is free to slide on a second tool rest.
I don't see anyway to prevent the tool from twisting on you and that may not be an issue as long as straight cutters are used.
Pretty ingenious in some respects but not a solution to everything....
Re: The Shape and Hollow Tool *LINK*
Steven Antonucci
Like trying to draw a circle on an EtchaSketch.
Brad Vietje
Brad Vietje
Hey Mike,
Looks interesting, but I'd like to see more surface area between the two cylinders for better support. Doesn't look like it would arrest torque from an angled or offset tool, but the straight-ahead cutters should work fine.
BTW: I followed the link you posted and tried his link for the video, which would not run for me, so I found it through YouTube at the link, below.
Safe spinning,
Brad Vietje
Newbury, VT
Shape & Hollow Tool on YouTube
Dick Coers
Mike,
I don't see anything that it can do. What is that double bearing system supposed to do? I can slide any tool along the tool rest, or set my hand on the tool rest and pivot against my thumb. Just don't see it. Maybe for the limited woodturners with one hand?
It appears to me to be a solution ......
JamieDonaldson
..... to a non-existant turning problem??? :\
Mike Stafford
Mike Stafford
I just thought it was an interesting approach to a captured tool system. I had not seen this method of capturing/controlling a tool before.
Just wanted to share something new to me and see what folks had to say.
Don Leydens
Don Leydens
It is an interesting concept, but I agree with Jamie and Dick. As much as I LOVE new tools, I'll put this one on hold.
Pete Black
Hi, I am the owner/designer of the ShapeNHollow tool system. I would like to offer some information on my system and its uses.
I am a very small start-up company and just can’t at this time offer all the bells and whistles that I would like, like a swan neck bar and various other cutters and scraper bits. These are available from others and if they work with a 3/4” or a 1” bar they will work with my tool.
Turners that have a swan neck tool that has a 3/4” bar can use it with my system. The only thing that I am aware of is that the cutting tip MUST be in-line with the tool bar NOT out to the side. I am not set up to prevent twisting/tool rotation but with the cutting tip in the proper position the swan neck tool will work like a straight cutting tool.
I will be posting an article in the next week with some pictures on my website showing my latest hollow form project and the tools I used.
A couple of things I was trying to accomplish with my tool are ease of use/flexibility and using the same tool system for deep hollowing and spindle type work.
For example, when you want to do a hollow form you can’t always just mount the piece on a faceplate and go. I usually put it between centers and get the grain or natural edge in a position to make it aesthetically pleasing, turn it to the desired shape, cut a tenon, and then mount it in a chuck. After you have the desired shape you can reposition the tool and hollow your project.
Spindle examples: When removing waste on the outside of any type vessel where you would be using a roughing gouge, or when you are doing off set turning, this system will be safer and demand a whole lot less effort.
Another example: There are tool rests with several holes drilled along the top to insert a pin to use as a fulcrum. The ShapeNHollow system can do the same thing, and my reasoning for doing this was to reduce the physical effort when you are just removing waste.
Whether you are working on an extremely out of round project or hollowing a closed vessel, at the end of the day you are not nearly as physically tired as you would be using just hand held tools.
Thank you for your interest in my tool system. If you want more information, please feel free to contact me. I am planning to post some short videos showing more set-up and tool positioning by the first of the year.
Mike Stafford
Mike Stafford
Thank you Pete. I came across your system and found it interesting and wanted to discuss it with the folks on the forum.
Perhaps their feedback can be useful to you.
Dick Coers
Nice of you to come on the forum Pete. Could you explain how the bearing holder improves on me just holding the tool by hand? It appears your system keeps the tool rest further away from the wood, thus increasing the force needed to keep control of the tool. The use of your small cutter slows down the entire process over using gouges, your advantage? I'm an inventor/builder myself, but don't sell anything. So the engineer side of me would like to understand your tool system. Thanks.
Peter Hyde
This is a captured system so there is no stress on the hand holding the handle of the tool and the front hand is used to guide it. Thought it was pretty obvious myself 8)
bob davis
the oland tool was developed by liz late husband..darrell rhudy one of his students taught use of these at john campbell folk school for several years. you went home after the class iwith 5 tools..two straight and two bent with 3/16 and 1/4 high speed steel bits. and a bent tool with scraper to smooth out the ridges.i still use them sometimes when i do not want to set uo the jameison rig for shallower hollowing..
bob davis
pic of oland tools
After reading all the posts I see some interesting uses for this tool. It does seem to function like a captured bar system by supporting the tool from the rear. It takes up a lot less space than some other captured bar systems.
I Like the idea of being able to rough out bowls using a captured system. Might take a lot of stress of us older guys with bad shoulders.
One thing that does bother me is hollowing really deep. It seems like you would need an additional bar to go through the captured system and have a collar that will accept the hollowing bar. Either that or have a very long bar to hold the cutter and goes through the captured system. I'll be interested to see how he does this.
Anyway it looks very interesting. You could feasibly weld on an outrigger bar like the Oland so it was behind the captured system. This would let you use curved bars that aren't in line with the cutter and it would eliminate catches from those curved cutters.
