3520B bearings
3520B bearings
3520B bearings
John Veerkamp
My PM has developed a tick that seems to be from the front bearing. There also is some vibration transmitting to the item being turned, I'm supposing that the bearing has gone bad. I can't feel any play in the shaft and it seems to run true without precision measuring..
How difficult is it to replace the bearing?
Is there anything else I should check?
Should I replace both front and back while I'm at it?
Thanks,
John
Re: 3520B bearings
Re: 3520B bearings
Bill Turpin in WNC mountains
Use a large, long screw driver (18") as a stethoscope. Put the tip on the housing close to the bearing. Put the handle against your ear flap. Push your flap closed. CAREFULLY rotate the shaft, perhaps use an assistant for safety. Any pops, cracks, grinds, scrapes, etc show a bad bearing. Check the other bearing in a similar manner. Always replace bearings in sets. Damage to one will hurt the other.
Re: 3520B bearings
Re: 3520B bearings
Richard Jones
John,
It's also possible that either the locking collar (for the spindle lock) or the inside collar (where the tach reads) is loose (I'm assuming the 3520 is made like the Jet). The rear locking collar on my Jet loosens about 3-4 times a year, despite efforts to the contrary.
Easy to check and fix. The tic that the rear locking collar makes sounds like it's coming from the front bearing...........
Rich
Re: 3520B bearings
Re: 3520B bearings
Ditto what was said above. First check the alignment of all the pullies and locking collar. Then tighten all the set screws attaching these. Most of the time that is the problem. Oh I forgot, the B has indexing. Check all that out and make sure it's parts are in the right place.
If that fails it could be the bearing. I've had my A series for about 8 or 9 years now and the bearings are still great. Don't know if they used the same ones for the B. Since I haven't tried to replace them I can't tell you how hard it would be. However a good machine shop can to a perfect job with all the proper tools and it would not be very expensive. I would consider that. If the bearings are pressed in it can be a bear to get them back in if you don't have the right equipment.
Re: 3520B bearings
3520B bearings resolution
John Veerkamp
Thanks for the help. It took the best part of 2 hours to locate the source. Richard was dead on. The tach collar was loose. Not an easy place to get to. I basically had to remove the shaft almost entirely to get to the set screws. But all is well and running smoothly now.
Thanks again,
John
Re: 3520B bearings
Dick Hines
Re:  3520B bearings resolution
Dick Hines
John, the next time happens, and it will. Take the locking button out and the hole lines up with the set screw in the collar. It will make it much easier to tighten the screw.
Don't ask how I know that.
Re: 3520B bearings
John Veerkamp
good tip. I'll need to get a longer hex wrench before then.
Re: 3520B bearings
Shouldn't have read your post
JimmyEdwards
Went to the shop at 8am and my front bearing was really rattling. It is simple to take the shaft and bearings out. I'm going to replace all 3 bearings. They lasted 5 1/2 years and I turn every day. The bearings aren't pressed on
Re: 3520B bearings
Brad Vietje
Brad Vietje
Dick,
John,
Thanks for the detailed info. Mine has a slight tick, but have not noticed any vibration, just an annoying sound. Have carefully tightened the set screws on the pulleys, and made sure the belt was not running slightly crooked...
Maybe the tachometer issue applies to mine, too. Has anyone taken or posted photos of the parts and screws we're looking for? I have not seen what's under the spindle lock mechanism, so I may have to schedule some exploratory surgery... Probably not on a night with snow and single digit temp's expected!
Safe spinning,
Brad Vietje
Newbury, VT
Re: 3520B bearings
John Veerkamp
If you hear the tick when you rotate by hand, it's probably the tach/shaft lock. Pull the spindle lock and look directly inside. It has four hex screws holding it. It is a black piece about 2" dia on the shaft. It has 2 set screws. With Dick's tip it would take about 5 min to fix it.
Re: 3520B bearings
Brad Vietje
Beauty!
Brad Vietje
Thanks -- I'll try to get in there on Sunday when we get back up into the 30's. We're at about 6 degrees (F) now, and probably close to zero in the AM... Too cold for metal work! I need a shop with heat!
Safe spinning,
Brad Vietje
Newbury, VT
