liquid epoxy question
Ilya Z
I was talking to someone about what what type of glue to use to fill cracks in my bowls and was told to use epoxy that is often sold at boat parts and repair stores because it's a lot more liquid than what's usually sold at regular hardware stores. Since it's almost like water it penetrates better. I don't have any boating stores nearby so want to try Amazon. If you've had experience with this type of epoxy, can you recommend a specific brand/product? Thanks!
Re: liquid epoxy question
Chuck Engstrom
Hello Ilya -- There are several varieties of epoxies sold in boat stores, some of them very thin indeed to penetrate into wood which has begun to deteriorate, others of more usual syrup-like viscosity. For cracks that are pretty small I'd suggest System 3 Clear Coat, which is available from Woodcraft online and their stores as well. It mixes up fairly thin but not watery, penetrates well, and has a long enough pot life that you can keep applying it as the crack fills up.
I have used this for cracks for about five years now and am still on my original small-bottle set from Woodcraft. I use 1cc hypodermic syringes without needles to measure it (it mixes 2:1 resin:hardener), and have had consistent good results using as little as 0.4cc resin/0.2cc hardener -- epoxies are too expensive to find yourself wasting $5 worth every time you need to use some. Sometimes I mix a bit of coffee grounds in to try to make the whole thing look like a bit of bark if I'm trying to fill a knothole.
Another good product is Smith's Clear Penetrating Epoxy Sealer, a water-thin epoxy mixed in equal parts and created mainly for restoration of rotten wood. I got mine from jamestowndistributors.com, a large marine outfit in Rhode Island. It is full of thinning solvents and tends to stink up the place, but it does work well on wood that has gone soft, where it soaks in aggressively and ends up creating wood that is part plastic, so to speak. I'm inclined to say it's too thin for filling or stabilizing cracks, since so much of it is actually solvents that evaporate -- you might keep adding more and more and finding you still have a crack.
Hope this is helpful. I recommend these brands only on the basis of successful use; there are plenty of other worthy products out there.
Best -- Chuck
Ilya Z
Thanks Chuck, this is very helpful. Which of these two products -- or maybe something else -- would you recommend for filling a bark inclusion?
Also, when you mix it up with coffee grounds, do they need to be particularly fine? In the past I've mixed up sawdust with CA glue but I want to move away from CA, so might try mixing sawdust with epoxy.
I use 2 products. West System epoxy is my favorite. I purchased 3 different thickeners for it which I've been playing with. It is water thin or close mixed straight out of the can with the slow hardener. A little bit thicker but not much with the rapid hardener. It works well up to toothpaste thick but once you get thicker than that you start to have some strange problems with air getting into it with some of the hardeners. If you mix in too much thickener it may not cure, so it's been fun. I like it and recommend it.
It takes colors well as long as you don't mix too much. I have used inks, water based and oil based paints, and powdered chalk all with good results. Water based analine dye didn't work so well, alcohol worked better.
I mix it using an accurate electronic scale. The ratio for the 2 hardeners I have are 1:3 or 1:5. So I squirt how much part A I want. Measure it, calculate how much part B and add it until it weights what my calculations say. It's worked every time and I don't have to mix up more than i need.
The other Product I like is System 3 mirror coat. It is very thin and gets even more viscous as it cures. It will actually penetrate the pores and tiniest crevices in the wood. It's too thin for many applications but if you need to pour it into a hole to fill the small cracks it works fantastic. I have used it to fill the internal cracks in Tagua nuts. I color the epoxy, cut off the bad end of the nut to expose the voids and then fill it with system 3. It will fill all the little hairline cracks and make the nut solid. It's worked great for my doll house lamps.
Chuck Engstrom
Hi Ilya -- For filling a bark inclusion or small cracks you'd want to used the System 3 Clear Coat. The other stuff is just way too watery to be useful; it's made up with plentiful evaporating thinners to help it penetrate rotten wood. Clear Coat is less viscous than most of the epoxies formulated for gluing and fairing, but it can still be used for those purposes with the addition of appropriate fillers. Because it is neither gooey not quick-setting, it will flow well into cracks -- you'll be surprised at how much disappears into what seems like a very small space. It is ordinarily an overnight cure but that depends on temperature as always.
System 3 does put out a downloadable 40-page book full of fundamentals and useful info at http://www.systemthree.com/reslibrary/literature/The_Epoxy_Book.pdf. This might be a handy reference for you getting started with epoxy work.
Coffee grounds can be whatever granularity you think is appropriate. They can be as coarse or fine as you wish, since the epoxy will penetrate into them to some extent and make them firmer anyway. Used grounds, fully dried, are what I use most of the time, and for that matter, you can grind up some bark if you want to be authentic.
Good luck with the project. Let me know if I can be further help. -- Chuck
Ilya Z
Thanks! Can you control viscosity by either warming up or cooling down the two parts before mixing?
Re: liquid epoxy question *LINK*
Ilya Z
Thanks John. Is this the WS product you use?
WS on Amazon
Chuck Engstrom
Hi Ilya -- yes, you can control viscosity by heating or cooling to some degree, but you change the pot life/cure time when you do. Warming epoxy will make it a little more runny but will accelerate cure substantially -- epoxy actually gives off heat as it cures, which is the main reason to mix it up in modest quantities that don't generate enough heat to cure more quickly than you can apply them. A coffee can full can go up in smoke, been there done that.
Cooling it will make get a bit thicker but slow down the cure. So it's all a trade-off. The very thin stuff I mentioned comes in winter and summer versions to account for difference in usual ambient temperature. Other formulas that work quickly at 85° in the summer will take overnight when you're back down to 60° or less.
You can use acetone to thin it some, and probably a few other chemicals as well (the System Three epoxy book may have some info).
Best -- Chuck
Craig Daymon
You might also consider getting it from Raka Systems. They also specialize in marine epoxies and the boating industry, but I find their prices much more affordable than West Systems (though I haven't checked recently).
Raka Systems Epoxy page:
http://www.raka.com/epoxy.html
-Craig
Brad Vietje
West System *LINK*
Brad Vietje
I'm with John. West System has epoxies for just about everything, and a great deal of tech support available. Really good, very consistent quality. My best buddy from college days is a master boat builder who turned me onto the stuff years ago. He's also an avid ice-boater (and ice-boat builder) who knows the Gougeon Brothers who own West System and Pro-Set epoxy -- turns out the Gougeon family includes some of the best ice boaters in the world.
On Thickeners and Such: Most epoxides are carcinogens, but generally not too dangerous if you take care about the liquid stuff getting into your body. Since the resins are relatively viscous and somewhat oily, they won't penetrate into tissues unless diluted with solvents, so be extra careful if you are making up very thin mixtures with acetone or other organic solvents. The dust from sanding is pretty bad for you, but the resins are already polymerized, so it's not the same cancer-causing goo that the liquid resins are. The really dangerous stuff is the powdered thickener ! You can buy a can of the lightest, fluffiest stuff imaginable to mix with your resin (West System 406 Colloidal Silica) to create different consistencies for different applications. That stuff is downright deadly: Be Careful, and Wear A Mask! The 406 thickener works very well, but I believe it is the very stuff that causes silicosis in stone cutters, granite workers, etc..., and it is in such a fine, flocculant powder that a sneeze could fill the room with it. The MSDS (found here: http://www.jamestowndistributors.com/userportal/show_product.do?pid=2035&familyName=WEST+System+406+Colloidal+Silica ) really soft-pedals the inhalation dangers. I may be wrong about the inhalation danger, but I would assume it is more dangerous than that just to be on the safe side.
Just for kicks, here's a photo of Jan Gougeon in a DN Ice Boat Regatta:
Jan Gougeon (DN1183) battles with Bernd Zeiger (48k JPG)
Happy epoxy-ing and Safe spinning,
Brad Vietje
Newbury, VT
West System Epoxy
Re: West System
Ilya Z
Thanks Brad. I did not really think about the safety side of this, so thanks for all the details. Will try to be careful.
Cool photo too.
