My brother has to put his dog down. He is a basset hound. I offered to make a cremation urn for him. Now I need to figure out how big "space" I need to make. Is it wrong to make it too big? I know I should not make it too small. I would be gratefull for any help.
Sean is correct - use the approximate volume of about 1 cubic inch per pound of person/animal.
For reference, a gallon is a volume of 231 cubic inches. You can do the math to proportionately reduce (or increase) the volume required inside the hollow vessel, and give you a rough idea of how big your blank and resulting vessel should be. For example, cremains from a large dog at 55 pounds would require an interior volume of about a quart.
For volume measurement in odd-shaped, non-cylinder forms that are difficult to calculate the volume for, you can fill the hollow vessel/urn with dry rice, and then determine the volume by using a measuring cup by measuring the rice.
Bit embarrassing when the family come around and I put in Grandma and she doesnt fit.(Often more than not the family ask if I can place in the remains )
