This is a walnut spiraled bowl that I turned. It is 12" in diameter, 5" tall and about 3/4" thick at the rim to accomodate the carving. I carved it using and Arbortec recripical carver and 3" sanding disk in a drill. The finish in 3 coats of Waterlox satin and 3 coats of Waterlox gloss. C&C Welcome.
Bob, this looks terrific. You are becoming a master of this spiral form. The finish on the wood looks smooth as glass so you must have spent quite a bit of time sanding and finishing. The result was well worth the effort. Good work!
Thanks Mike, I enjoy doing this type of work. I am working on some boxes with spiral patterns but, am having trouble with the lid designs. Any suggestions would be appreciated.
Bob That's really nice. Is it the first spiral bowl you've done? Personally I would have run the spirals on up the face and done away with the lip but then that's just me. Of course it would have been fun to have them come all the way up and leave the top jagged with rounded over spiral tips, kind of like a John Jordan accent to the piece.
I have done a couple with the spiral going all the way to the top and like them to. They are actually easier to do because you don't have to taper the spiral to an end. I haven't done one yet that the spiral was rounded at the top. That would we interestng. Thanks for the suggestion and comments.
Boy I agree. doing a stopped cut at the top of the spiral and rim is a pain in the you know where. I have sketched out plans for a vessel with both horizontal and vertical lines. Haven't built it yet and I know the juncture between the two elements is going to be a hassle.
John, don't worry about the sanding. Bob is a sanding wild man and will gladly accept any turning you can through at him for immediate sanding. We all kid him about that at the club, but his spiral forms are really taking off and he keeps getting better and better no matter what form he throws these spirals on. Great work, Bob. Another beauty!
