Veritas - Innovation in Tools
Dead PM3520A
Dead PM3520A
Dead PM3520A
Hal Taylor
I went out today to start turning again after a few weeks off. Put on a small blank which is going to be a hollow form. Turned on the lathe like I usually do, turned the speed up a little, and started to round it with a bowl gauge. Was cutting OK then I took a little bigger bite, and it sounded like the VFD went out. Unplugged the unit, waited for the VFD to reset, which it did, and started turning again. It happened again but with less cutting pressure. Now after resetting the VFD, pulling the switch and barely turning the speed up from zero, the motor does not turn and the VFD quits. When it quits the code is "occ".
Called Powermatic and with a little testing it sounds like the VFD is doing fine. They suggested blowing out the motor, but it seems to be sealed. The motor turns freely with no suggestion of bearing problems. Help!
Re: Dead PM3520A
Re: Dead PM3520A
Alan Trout
It could be bad windings in the motor. It sounds like the motor is overloading the VFD and it is tripping. If you have an electric motor shop in your city pull off the motor and take it in. They many times can test it for minimal cost. If nothing else it could rule out the motor as the issue.
Good Luck
Alan
Re: Dead PM3520A
Re: Dead PM3520A
Hal Taylor
Thanks Alan. That's my next step. I now have the motor off.
Re: Dead PM3520A
Re: Dead PM3520A
Galen Vetterick
What did Powermatic say the code "occ" ment? If they told you to blow out the motor they might have ment the cooling fan. Could be the motor is getting too hot and the fan is not cooling sufficient. From what you said it sounded like it shut down faster each time and maybe just cooling enough to rest a thermal sensor but it does not take much to rebuild the heat for another shutdown. Just thinking what they might have been saying.
Re: Dead PM3520A
Re: Dead PM3520A
Hal Taylor
PM told me to blow out the motor, but I could not really see how to do it since it seems to be pretty well sealed.
I did get the motor checked out, and just got the call. Motor is fine. Does that mean it's the controller or is there something else it could be? Is there a way to determine if the controller is functioning properly? Appreciate the help.
Re: Dead PM3520A
Re: Dead PM3520A
Nick Todd
If the controller & motor are ok, clean & check the connections in you on your power button.
Re: Dead PM3520A
Re: Dead PM3520A
Bill Howatt
The clue probably is what does code "occ" mean. Do you have any documentation that would define it? If not, I think you should call PM and ask.
Since the motor is OK, I'd my guess is the VFD has a problem particularly since it worked but then tripped out and hasn't worked properly since.
However, I'd reseat all the connections possible and clean/blow-out all the switches. I have a home-made control box for my General 260 with industrial type Start/Stop pushbuttons mounted on it and when the lathe won't go, I have to blow the switches out. I am amazed that any dust can get into them but it seems to. However, your problem is a bit different in the way the problem first manifest itself but it's worth a try.
Bill
Re: Dead PM3520A
Re: Dead PM3520A
bill Crommett
I used to have a dust problem with my General 260 that required taking the switch apart to blow it out. It has been a while, but I no longer can use the lathe and wish someone would make me an offer.
Re: Dead PM3520A
Re: Dead PM3520A
Hal Taylor
The occ code is "Over Current, IGBT protection (Insulated Gate Bipolar Transistor)" from the VFD-B manual. I hope to get in touch with Delta to find out some more information.
