Bumpy Segmented Bowl
Rick Haverstock
I normally hang out on the flat side, but have been experimenting lately with segmented bowls. I've pretty much got the hang of things, except for one problem. Finished up a nice 12" maple bowl with a bloodwood rim, sanded through to 600 grit and finished with General Finishes Salad Bowl finish. After a few weeks, the pristine smooth surface has some small bumps, not that you can see, but can feel with your fingertips. Maple/bloodwood was kiln dried, Titebond II used for the glue-up. Am I correctly guessing that the additional moisture introduced by the glue was not completely dry after turning and sanding ? If that's the case, how long should I wait before finishing?? By the way, these were done in my heated basement shop. Any suggestions from the spinning tribe? Thanks!
Rick Haverstock
Re: Bumpy Segmented Bowl
I call it glue creep
Others may disagree.
PVA glues often express themselves at the glue line when used for laminations. I try to use glues that don't creep, like plastic resin glue or Unibond 800.
Re: I call it glue creep
I'm not sure exactly how long you should wait but the longer the better. I waited a week when I did my last segmented piece and I used Titebond 11. It's about a year old and still doesn't have bumps. I used to have that problem a lot but ever since I read Malcolm Tibbits tip on letting the vessel sit before sanding my problem seems to have gone away. I don't do a lot of segmented work so my results may be limited.
bill Crommett
I have had a lot of glue creep doing flat stuff, but with segmented bowls I use the white Titebond trim glue which is thicker and requires a lot of stiff rubbing to make a good joint. Very little, if any glue creep with this glue.
gtwilkins
Being that there is a certain amount of creep with any of the PVA glues would liquid hide glue be strong enough for segmented turning. (thinking of Old Brown Glue or Titebond)
I have read that the strength is only slightly less than that of PVA's but with the high tack it would be good for rubbing joints but is it too brittle?
Trevor
Rick Haverstock
Thanks for your insights guys. I had read Tibbits' book some time back and must have missed the wait before sanding/finishing tip. Guess I just have to have more patience on this.
Rick Haverstock
