Looking to find
Gary Smyth
tailstock MT2 center, hollow, live center, and boring tool. Alternative to Packard offering.
Looking to find
Gary Smyth
Re: Looking to find
Are you looking for something for drilling lamps like a lamp auger and hollow #2 morse taper for the tailstock?
yes
Re: Looking to find
Mike Mills
I don't know if the Nova meets your needs or not.
Re: Looking to find *LINK*
Gary I use a combination of things. I use the Hollow center from Craft Supplies part # 064-0023.
http://www.woodturnerscatalog.com/p/4/-/12/65/-/5331/Precision-Machine-3-8%2522-Hollow-Center/hollow+center
It is a dead center but has a short #2 morse taper on the rear. This just happens to fit the Nova Live Center Part no 100-0005. http://www.woodturnerscatalog.com/search?term=100-0005 I highly recommend this live center. It's so incredibly adaptable because it's very easy to make wooden adaptors to fit the short #2 morse taper.
What I did was drill an extra hole in the side of the hollow center to help clear the shavings. It has a setscrew to remove the center point. I simply drilled through that hole and on threw the other side.
What I do is center the wood on the hollow center and push it in hard enough for the ring to contact and mark the wood. then I back it off and remove the center point. I crank the tailstock up until the ring contact the mark I made and this centers it. If centering is not critical just remove the point and use the ring portion.
Both will work, thanks. Now for the boring rod
Re: Both will work, thanks. Now for the boring ro
Craft supplies sells that also. It's called a Lamp Auger. If you buy one sharpen it. Mine came OK but after I sharpened it using diamond hones it cuts better. If you force the cut it will follow the grain worse than normal. If it's really sharp and you take your time and don't force the cut it will tend to drill a straighter hole.
I drill from both ends toward the middle. That way if it's off a hair it will self straighten in the middle so you an run your wire.
bill Crommett
When I made lamps, the lamp auger always wanted to follow the grain,, so I began using a bigger blank to start with and cut off the drive end and centered the workpiece on the final hole. No worries about running out the side anymore.
