I usually post on the Flat side of this site but I know that the folks here will have the answers I need.
I just cleand up an old Craftsman lathe (single tube for a rail). It is 40" between centers and runs great after the rust came off! My question is what is the best design for a stand and how tall should the stand be?
The 'average' height for a lathe is to have the spindle height equal to the height of you elbow to the ground. Remember, this is average, your mileage pay vary.
Make it solid and strong with cross bracing so it will not flex or wiggle, add a box under it for sand to add mass. The heavier the better. Use leveling feet if possible. A good stiff strong stand will let you get the most out of a starter lathe.
Ditto what both have said. Especially a heavy stand. That lathe doesn't have a very slow, slow speed, so you'll want a heavy stand. I've seen several people add what's called a Jack shaft to the lathe. This is a second set of pulleys that allows you to get really slow speeds for turning bowls. You can probably find info on that by doing a google search. I just did a search using the words "wood lathe jack shaft" and found lots of info and pictures.
I built my lathe stand about 14 years ago for a Nova 3000 using the basic plan in the Nova 3000 Operating manual. For the last ten years, it has had a Nova DVR mounted on it. It is bolted together and has stood up very well. I used 2"x6" boards throughout, but basically used the drawing in their manual from the Teknatool Web site. The drawing is currently on Page 8 of the Nova 3000 manual downloadable from Teknatool's web site, given below. I filled the box on the bottom with scrap steel that I had on hand from my blacksmithing days, but sand might be better, and perhaps cheaper.
If you can't access the web site to get the manual, send me an e-mail and I'll send you the drawing as a *.PDF file.
