Veritas - Innovation in Tools
Haze on Finished Piece
Fred Holder
The following question was posted to me that I can't answer. I thought perhaps some of you guys might be familiar with the finish and possibly the unknown wood:
"A white haze covering large areas of finished bowls. This appears on one specific wood with a finish used for 5 years on many species of wood. The haze is easily removed by wiping but will reappear and finally stop after a period of time of rewiping.
1) The finish used is TRIED AND TRUE varnish oil, a polymerized linseed oil and natural resin varnish.
2) The haze does not form on untreated bowls of the same wood. This has not been seen on any other species.
3) The wood is unknown but is a very dark swirley grained, hard wood. The bowls are turned from blanks cut from a large piece 3"X 6" by 5 foot that sat in dry storage for years here in New Mexico. The piece originated from Mexico.
Aside from some nuisance it is a curiosity."
Re: Haze on Finished Piece
Carole Valentine
Sounds like what happens to Eastern Red Cedar sometimes when the resins come to the surface. I solved the problem with a thin lacquer wash, wiped dry and allowed to completely dry before the final finish. Not knowing what the wood is though, it could be something completely different.
Harry Robinette
Harry Robinette
Fred
When I lived in Clovis NM for 9 years I had that problem with tried and true on a table top I did . I was told by a couple guys I knew from the old hobby shop on Cannon AFB that the varnish in the tried and true does not dry fast enough for the oil to be sealed in and it allows the moisture in the oil to raise through it.
Like I said thats what I was told. I use Tried and True allot here in Ohio and never have any problems.
Barry L Elder
Fred, in #2 there is a reference to "untreated" wood or bowls. So what is he "treating" the bowls with that have the haze? Seems to me to be the key.
Fred Holder
Hello Barry,
I think he is just putting TRIED AND TRUE varnish oil on the sanded wood, with no sealer. Since I've not used this finish, I can't give any opinion on what it will do to the wood.
