Reproduction finial
Reproduction finial
Reproduction finial
I did this for a friend who likes to put antique architectural stuff in his house. He likes the chipped paint. This cornice was missing the finial so I turned one.
The photo on the left is after I put 1 coat of white paint on with wax sponge painted on. After the paint dried I stuck masking tape to it and peeled away much of the paint. Then I sanded and steel wooled it back some more. After that I sponge painted 2 different brownish/yellow colors around to pull the white down some.
Then I mixed up some gray dye and sponged it on to take some of the brown color out of the wood.
Then I masked it off with masking tape and cut out areas. I painted it white and then green.
I mixed up some white Gesso and stirred in a little epoxy and thickener. I took this mixture and painted it on some metal, aluminum foil, plastic carton, and some stretch wrap wrapped around my anvil. These areas were covered with Johnson's paste wax. After they dried I peeled them off and painted them green. Then I cut selected pieces with the right curve and cut out sections. Glued these to the form.
Then I went back an made cut marks similar to the cracked paint. Took it out to my fire pit and rubbed ashes on it to dull the paint. I think I need to do a little more of that. The wood is still a little to new looking. Maybe some exposure to sunlight will darken it a little.
I'm happy with it and know my friend will be.
Re: Reproduction finial
Steven Antonucci
Instant antique
