i'm having issues with some finishing... i want to use high gloss poly, and applied with a brush, but i get streaks.. so i sanded down and switched to wipe on poly... applied with bits of old t-shirts.. still get streaks... sand down to wood, use wipe on poly with brush.. still get streaks..
When I apply wipe on poly, I first use dewaxed shellac as a sanding sealer [Zinzer seal coat] and then when dry use a folded up piece of t-shirt or at times some of the blue shop towels you can get in a roll.......I usually generously put on the first two coats, then go thin and build a finish that is smooth.
Sanding with 600 grit or even a little higher will knock back the nibs or smooth out any ridges you got on the previous coats, the try to apply a couple more thin coats.....I like to apply mine while the project is still on the lathe at a slow rpm...say 50-70 rpm........unless it is a pen or smaller spindle then a little higher rpm is okay......
Hey Darrin, my thinking is that you are trying to apply too much poly to the surface in one coat and getting the streaks and ripples in the process.
The method I use for wipe-on poly is to use a small swatch of lint-free material (such as an open pore foam rubber) to rub a continuous coat onto the surface and then wipe most of it back off. This leaves a thin, glossy film that is not thick enough to produce ripples, and if you are careful with the rubbing, it should be free of streaks as well.
Apply only enough poly to the swatch to produce a wet-looking surface but not so much that the poly tends to flow over the surface.
With fresh poly applied in a thin film, you will have only a couple of minutes before it will start getting tacky. Before this happens, stop the rubbing and set the piece aside for the poly to dry. Then, later, apply additional coats until you get the desired shine or luster that you want.
If the wood is porous, I will seal it by brushing on lacquer sanding sealer (applied with a small artist's brush). After the sealer cures, I then smooth the surface with 320 or 400 grit abrasive, or 0000 steel wool, and then apply the poly.
My wife suggested triangular makeup sponges and I tried them. They work great. They hold enough poly to put on a light coat that is smooth. It's easy to remove any drips with the sponge as well. They are inexpensive and come in bulk. I pour a small amount of poly into a small plastic cup and work out of that instead of the can. When I'm done, I drop the sponge into what's left of the poly. It absorbs the residue and dries. When it's dry, everything goes into the trash.
I apply it liberally but then wipe it all off. Your poly should be pretty thin. I've had streaking problems with old wipe on poly. When it starts to thicken it's not good. Toss it. I've tried thinning and it still doesn't work very well. It's not a high build finish. It takes multiple coats to get a high gloss especially if you have a punky area or some other area that soaks up the finish.
Most steaking comes from working the finish too much. Wipe it on and leave it alone. If less than 30 seconds goes by, you can still wipe it a little, but more than 30 seconds, leave it alone. I leave a very thin film on the work, and do not wipe it off. I with a small ball of t-shirt, or even a ball of paper towel. Very light dipping in the material, just enough finish to make it look wet. Just get it on, and leave it alone. No finish is good as applied. It all needs to be sanded to level it, remove dust nibs and bugs, then polished.
it depends. Steel wool leaves a low satin finish. Somewhere between matt and satin. Wipe a coating of wax over it hand rubbed in and it is closer to a satin or even more glossy than that. Buff it, or apply more thin coats and it will become glossy. You can also simply sand it with finer and finer grits going up to the micron papers if you want really glossy.
You can also use Automotive polishing compounds to bring up the gloss if you want really glossy.
