Don Orr mentioned "cutting pace" below
steven antonucci
I thought it bore mention in case the thread below wasn't revisited by some of the folks that might have missed it. "Cutting pace" is actually the same term I use, so Don's hit on another important topic.
When I describe the cutting pace, I use a few variables to explain what you are trying to accomplish. The pace of the cut is dictated by how large the shaving is AND how efficiently the gouge can clear it, the type of wood, the speed of the lathe, the dryness of the wood, and probably another 2 dozen things.
I usually demonstrate it on the inside of a bowl by starting at the rim to get bevel contact, and then proceeding to cut with three fingers loosely gripping the end of the gouge. The slightest amount of forward pressure produces a cut. Stopping the pressure means no cut.
The pace is to move the gouge through the arc to produce a shaving with the same width from top to center, which means that you need to slow down as you get closer to the center of the bowl. At any given time, any tool is only capable of moving at some pace that is dictated by the shape and sharpness. Moving faster than this pace produces a diminished result.
Another good topic...
Steve
