Trembleur Tournoi ( or is it Tournoi Tremblleur?) *LINK*
charlie belden
How'd you like to be a participant in a Trembleur Tournoi (Tournament) - with Escoulen as a judge?
If you have to enclose what you've turned - as you go - in a glass tube in order to keep it from snapping off as you remove it from the lathe . . .
Wonder if you turned your lathe on its side - headstock up - and suspend the trembleur - if you could go thinner than if stood upright. Wood is stronger in tension than in compression.
Borderline Insanity
Re: Trembleur Tournoi ( or is it Tournoi Tremblleur?) *LINK*
Count me out
Wow, what a collection of trembleurs! The steadyrests were pretty amazing, too.
Thanks for posting this, Charlie.
Don Leydens
Very enjoyable video
Don Leydens
Amazing stuff. The glass tubes were a great way to both protect and display those delicate items. Six steady rests? Very cool video, thanks for posting it.
Charlie I did a small one years ago. I still have the string steadies. Nothing even remotely comparable to that. I couldn't figure out what I would do with it. But then what have I done with my micro goblets. :) At least they are easy to store.
I had a shopsmith once. It could easily be turned up in it's drill press mode. Can't remember if the tailstock would fit when it's in that position. I think it would be hard to turn sideways. It would certainly take practice.
Steven Antonucci
Like any trick...
steven antonucci
if you know how it is done, it is not all that hard.
The steady rests take up all of the risk. If you've ever seen JFE turn with a simple string rest, it is astounding how much support you can get using a piece of dental floss...
I would bet most competent turners could do this given the right basic instruction. I turned one 18" between centers, using my left hand as a steady rest!
It also doesn't hurt if you look at some of the names in the credits. The guy who turned the chinese ball in the one element is my hero...
Steve
Jesper, Denmark
Re: Not borderline, pure insanity - but impressive
Re: Like any trick...
charlie belden
Not sure I'd call it a trick, trick implyng deception. Technique might be a better word to use.
The two techniques critical to successfully turning a trembleur are
- progressively turn, sand and finish small increments, starting from the tailstock end and working
back towards the beefier headstock end
- LIMITING the amount of movement of the already turned part of the trembleur
It's easy to think that the "steady rests" firmly hold the delicate part already turned and keeps the turned part bound, except for rotation around the lathe's axis. What the steady rests ACTUALLY do is LIMIT the movement of the already turned part's (ie wobble) to a level that won't tear the piece up.
A set of String Steady Rests (using waxed dental floss, preferably the flat "ribbon" floss) are easy to make and easy to to "thread", constraining the turned part between opposing "Vs" of dental floss.The wax on the floss acts as a lubricant so there's no marring of the turned part it's holding.
Steven Antonucci
That's the rest I saw JFE use...
