Re: Respirator *LINK*
David Walser
Check with the folks at Airware America. They were able to locate a replacement face shield for me a couple of years ago. Their website does not list this particular part, but they might be able to help.
If your existing face shield is merely scratched up, you might be able to save it by buffing out the scratches. It takes some time, but it's doable. I used Don Pencil's plastic/lacquer buffing compound (starting with Tripoli). You can also use micro mesh -- it's used to remove scratches from aircraft windscreens.
Good luck!
http://www.airwareamerica.com/tritonworkshopsystems.aspx
