The Rule of 10,000
charlie belden
You've probably read or heard about The Rule of 10,000 - you have to do something 10,000 times before you've mastered doing it. And the implication is there's no exception to this rule - and that it will take years and years.
If it takes an hour or two to turn a bowl, and you turn 8 hours a day, 7 days a week, that's 56 bowls a week, it'll be close 3 to 6 years to get to your 10,000th bowl.
But what if . . .
you could cut that time in half or by a quarter?
You CAN - if you turn miniatures.
You can turn a Mini in 10 or 15 minutes. AND you don't use much wood, don't have to sharpen as often, don't need a big powerful lathe, a rack full of turning tools nor have to sweep up - and dispose of - garbage cans full of shavings. The cuts you use to turn a mini can be the same as those used for full sized turnings and the tools to make those cuts can be the same type(s), just at a different scale.
Why aren't new turners started off turning miniatures? The types of turning tools can be the same, just smaller. The fundamentals are the same, just with a smaller range of motion. The tool control is the same, perhaps even tighter than for full sized pieces . The forms can be the same, just at a smaller scale - proportions are proportions, regardless of the scale at which they are applied. And a catch while turning a miniature is much less dangerous than a catch while turning a full sized or BIG piece.
For new turners, confidence is often an issue. After all, shoving a sharp tool into a piece of spinning wood seems like a really crazy thing to do - unless you understand the mechanics of the process and know how to apply that knowledge. What better way to acquire that knowledge and learn the fundamental skills than turning miniatures?
Just something to think about - or not . . .
I made the conscious decision long ago that if I can't easily lift a piece of turning stock high enough for mounting on the lathe, I have no interest or reason to be turning that beast.
