to superglue, or not to superglue
darrin hill
so i'm making a small round hf out of elm, and i want to add a piece of walnut for a rim..
would u use Ca, or tightbond, or which to join? just wondering preferences..
darrin hill
Re: to superglue, or not to superglue
Philip F. Duffy
In that application I would use TB glue. CA is fine in lots of applications but when it comes to wood-on-wood, nothing beats wood glue. my2 cents. Philip
Mike Gibson
Tightbond and make sure it is the Original. Michael.
johh lucas
Wood movement is your biggest issue here. I try to align the grain if I can . Then I prefer to use a glue that is not brittle. CA is brittle and is starting to get a bad rap in the gallerie and museum venues. The traditional woodworking glues have a very good reputation and a know record of holding up. Now that doesn't mean that I've never used CA glue and I have. This kind of application doen't require a stong bond. If your gluing a fnial on that's different since people often pull on a finial. Glueing the spouts and handles on Mike's T pots is much more stressful and requires a well made joint as well as a known strong long lasting glue. PVA glues are also far less expensive than CA glue.
Rob Wallace
I made (and still make) a lot of hollow forms with one-piece collars of a contrasting color/figure. Previously (maybe 12-14 years ago) I had used CA glues to attach them, and many, maybe most (?), of the collars glued-on with cyanoacrylate have come apart. I just repaired one of these last week.
Since I was advised against using CA glues for anything 'archival', I switched to using 2-part epoxy (5 minute), and every collar I have attached (as far as I know) since that time has remained attached - at least for the last 9-10+ years I've been using it.
I will not use cyanoacrylate glue for anything but a narrow crack repairs, infiltrating knots, coffee-gound inlays, powdered metal inlays, and other minor "fixes" that are not anticipated to have much stress or shear due to wood movement.
Little of my experience includes using PVA glues for this type of application (with some exceptions of doing a few segmented pieces using Titebond I), but the inherent "flexibility" of this type of glue would be an advantage.
"Stay away from CA" if you can for these kind of applications!
Rob
What's the moisture content of the wood?
Dick Coers
If it's much above 20%, Titebond will not work. CA will, but you've gotten the good advice about long term CA.
wood glue
Silcone
Steve Mushinski
Silicone and have the fit not too tight. Leave just a little room for movement and the silicone will do the rest for ya.
