Minor Safety warning
steven antonucci
Sometimes, you need to listen to the little voices in your head... take the tailstock down... at least take the point out, you big dummy...
Stupid is as stupid does...
Steve
steven antonucci
Steve
Re: Minor Safety warning
robo hippy
You know you are a woodturner if you have a little hole in your elbow from the tailstock!!! Not original, but one of many sayings.
robo hippy
Turner's elbow on the wrist! It's spreading!
Craig Daymon
Aaaaargh! Call in the CDC!
Keep us posted on your recovery.
Warning labels are on the way
As Craig said, when the CDC hears about this we'll have warning labels, mandatory child proof caps or they might take them off the market like they did Lawn Darts and require they be made out of plastic. By the way I still have my illegal Lawn Darts. They are so far superior to the ones after the ban it's not funny.
Been there, done that, cussed like no tomorrow...
Re: Minor Safety warning- I see the point!
Galen Vetterick
Tailstock removal is not a big deal on my little Jet 1220 like most of your larger lathes but I try to keep a rubber cap on the live center regardless if it is mounted or stored. The stored position is dropped in a hole at the end of the lathe ( yes point up) so yes I found it safer to keep the cap on untill needed. Don't ask me why I learned to do this in both places.
Experience is what you get right after you need it
Chuck Bjorgen
Or hammering a drive center to remove it from the head stock and catching it with your bare hand. Do it more than once, shame on me.
Mike Stafford
I think I have at least 7 scars on my right forearm from the point of the live center.
I am a very slow learner.....
I teach my beginners to grab a handful of shavings
steven antonucci
and it pads the spurs. Oneway centers will draw blood.
Steve
repetition aids in rentention
steven antonucci
Sooner or later, you'll have enough scar tissue that it won't be an issue...
S
you're lucky...
GaryG in MD
that you didn't react by recoiling and jamming the tool into the spinning workpiece, at which "point", it would have destroyed the piece and/or whammed down on the tool rest after going for a counterclockwise ride. Consider yourself lucky. I ALWAYS remove either the point or, more often, the entire tailstock. ...GG
Re: repetition aids in rentention
Mike Stafford
Need a tilt down mechanism for the tailstock like the hydraulically assisted one on the Wivamac.
Or I need to remember to remove the live center. Wonder which solution is cheaper?
Emmett Manley, Lakeland, TN
Keep a half drilled golf ball on the live center point -- you will discover a dozen uses for the golf ball, beginning with the protection function.
I love my swingaway thingy on my 2436!
Mike Stafford
I agree with you Emmett about the golf ball. The inimitable Mr. Donaldson taught me that trick and since I live on the golf course there is no shortage of golf balls however one must remember to use one if one is to avoid wounds.
Most of the time I poke myself with the live center point it is because I am in a hurry. Never a good plan.
The lathe was off and no tools in my hands
steven antonucci
I had made a jam chuck to reverse turn the foot on a small bowl, and it was a really tight fit. Tight enough that i needed to lock the headstock and use both hands... and then when it gave, the point was close enough to bump me.
Based upon the recent safety conversations, I figured it made sense to bring up a common (sense) injury and point out that even simple things should be thought about while in the shop. The more complex, the more you should think.
Steve
Agreed...
GaryG in MD
The way to prevent accidents is to think ahead and try to picture dangerous scenarios, even low probability ones. Lynne picked exactly the wrong time to take a close look. That thing could have exploded at any time earlier or later, and she would have been fine. We call that bad "luck", but it shows how you have to constantly plan for the worst-case scenario. I'm generally "overly" safe at the lathe, but things like this give me pause and make me think even harder about no-no's. Before this, I have sometimes gone to the grinder without my face shield -- no more, thanks to one of the earlier posts triggered by this incident. ...GG
Re: Warning labels are on the way
Steve Kniffen
One of my students works in a sheet metal shop and also makes plastic signs and decals. He brought me a stack of stick on signs that said "This Machine Has No Brains - Use Yours!" I've got one on the door to my shop to remind me as I enter.
Make a cap from PVC pipe fittings
Scott Crumpton
I made a cap from some PVC plumbing parts. All that's needed is a short length of PVC pipe that will fit over the center and a PVC end cap. If you want to make it fit snugly, line the inside of the pipe with the loop side of some Velcro for friction.
Wayne Kuhn
Copied, formatted, printed, laminated and posted in my shop. Great reminder.
Re: Make a cap from PVC pipe fittings
Bernie Weishapl
Thanks Scott. I will borrow that idea.
Don in Central Illinois
That's what John Lucas uses to glue his mirrors in placw.
