tips on not getting hit- kind long but important
We are having some very good discussion on faceshields and along with that some good tips. I thought I would try and throw some out there. I've never been hit in the face with anything other than some bark. I have only had a few pieces come off the lathe or blow up and didn't get hit by those. Maybe I was lucky and these discussions prompted me to buy a face shield and hopefully I will wear it more. Anyway off to the tips to avoid getting hurt.
First of all turn good wood. Keiths tips on cutting around the cracks is excellent. I do that. If necessary I'll simply turn that log into pieces as small as ornament balls. The thing is, you don't have to turn a big bowl out of every log. If it's starting to crack, make it smaller. Better to use a small piece of wood for a box than get hit trying to turn a bowl.
Look very very hard for cracks or defects. After I cut the cracked end off log I will cut another 3/4" slice. Then I try to break it. If it breaks easily there was still a crack I couldn't see. I cut more thin slices until it's solid. Then I cut my bowl blank.
We all love to turn crotch pieces but they often have voids or bark inclusions. Be extremely careful with these, wear protection and stay out of the line of fire.
I started turning with faceplates and drilled extra holes in them on advice from the experts. I used big long screws. That may be why I didn't get hurt early on because my lathe would not go down to slow speeds and my technique sucked. A faceplate with a bunch of good screws will win over a chuck every time. Screws going into endgrain may be the exception but there are ways around that and it's still probably better than a chuck.
When using a chuck, make the tenon fit the jaws. Make a square shoulder on the tenon so the wood sits on top of the jaws as well as inside. This prevents rocking which loosens the jaws and the piece flies. Stop periodically and re-tighten the jaws. The vibrations from turning cause the fibers to crush and the wood gets sloppy in the chuck until it flies off. If you expand the jaws into a mortise, make sure there is plenty of wood outside the jaws. Check to see if the grain runs out, that's an area of possible failure, and make the opening fit the profile of your jaws. Also on expansion or contraction try to make the tenon close to the size of the jaws so they contact the wood as much as possible . On 2" jaws for example make the tenon about 2 1/8 or 2 1/4. If you make the tenon 3" you only touch the wood at 8 small points. These crush the wood more easily and will loosen quicker.
Pay attention. Many injuries happen when applying the tool or pulling the tool back out. You inadvertently touch the wood with the tool while it's not supported on the tool rest and BAM, you know the rest. I did just that during a demo the other day. I was talking instead of paying attention to what I was doing and touched the rim of a platter. I was lucky, nothing bad happened but it sure could have.
Use proper cutting techniques. Learn what causes catches. Most of the time it's getting an unsupported edge into the wood. Lyle Jamieson wrote a great article in American Woodturner a while back on this issue. If your an AAW member you have access to all the previous Journals. Look it up.
Don't extend the tool over the tool rest any further than necessary. It gets hard to control the tool when you have 3 or 4" hanging over the tool rest. Stop and readjust the tool rest.
Watch the speed. Always turn the speed down before you turn the lathe on. This is especially true when first starting up. You may have been turning a spindle at 2400 rpm on your last project. You start a 16" bowl at that speed and you better run for cover.
Stay out of the line of fire. This is impossible to do 100% of the time. By line of fire we mean the direction a piece of bowl might fly if it blows up and comes off the lathe. This is usually perpendicular to the bed of the lathe. I can do that most of the time until I need to really see the form of the bowl. Then I'm forced to lean in a little. That's the dangerous time. Make sure your tools are sharp, you aren't forcing the cut, you have good control of the tool and hopefully you have a face shield on.
OK this is getting long but hopefully I've helped. There are other preventative measures and I'm sure someone will post those.
