Question for you experts on short main bevel
I've noticed that several top turners are now using a very short main bevel and then have a secondary bevel right below. I've heard that it reduces friction so you can "feel" the cut better. I've been playing with it for about a year or so now. It does seem to do that. I also find that it doesn't leave the little bruised lines that you often can get on the inside of a bowl. Anyone else want to chime in on why people are doing this grind.
I was talking to a master machinist the other day. I'm trying to learn and I'm on the low end of beginner. Anyway he told me that if you want a really clean cut on a tool come down about 1/16" and grind away the lower part of the cutting edge. This gives the metal a place to expand into after the cut. Well this is exactly what Mike Mahoney's tools look like and what I've been trying to duplicate. I'm wondering if this actually works in wood. You also see a chip breaker groove cut just behind the cutting edge on the top of carbide tools. This is supposed to help clear the cut and leave a cleaner surface.
He has skills I doubt I will ever possess.
does it work? yep.
The bottom is a Thompson V gouge that I grind on the Wolverine jig. I grind the main bevel and then move the tool forward in the slot to where the V joins the arm and grind the second bevel. Then I pull the tool out of the Wolverine jig and freehand grind the sharp edge off the bottom bevel.
