Parting with my parting tool
Mike Foster
I have been out in the shop preparing a blank for one of my minimal surface pieces. I decided to use a burl that I have had for over 15 years and has traveled with me from Colo to AK and I still have some of it. I have made several fairly special pieces with it as the figure is pretty spectacular and unusual. I bought it from guy that cut up burls and resold them to crafters, turners..... But on a very large scale. His shop was amazing. He told me the burl was elder burl, but now I really have no idea what it is. The feature layer in the piece below is that wood. Kind of similar to maple burls, but I don't think it is that. There were large (2-4") lobes on the outside of the burl, not little points like on maple burls. So I still call it elder burl, but I'm not sure there is an elder tree.
So I still have the core from the piece below and decided to use part of it on this new piece but wanted to preserve as much of the wood as I could. I only needed part of the core, so I decided to mount and part it, as the core was round, and I didn't dare risk taking it to the bandsaw. The core is about 9" in diameter and pretty bone dry. I could have used a Kelton straight tool, but the kerf is twice the size of a parting tool. So I grabbed the nearest parting tool put a new edge on it and went at it. I had intended on cutting though with a handsaw, but wanted to make it as easy as possible but parting as far as I could. I was about 3" into the blank and the when I got a catch and bent this parting tool. It is a shopsmith tool that I got when I first started turning over 22 years ago. Carbon steel, and not real hefty. I was still surprised that I bent it. I actually stalled the Beauty as well. That wood is a little prone to catching due to the varying density swirling grain. It also has some small bark inclusions and possibly some little cracks. I knew I was pushing the limits a little especially with this wood. Still couldn't believe that I bent it. I liked that parting tool for the nostalgia, and it still worked fine.
Re: Parting with my parting tool
Guy Bratt
That is a very nice piece. If that tool has meaning. Maybe you should mount that tool minus the handle in a frame with a picture of the finished project that you were working on when it bent. Just to hang in the shop. Probably include this story.
Mike Stafford
Mike Stafford
I may have one in my shop if you want a replacement. Let me know....the price is right.
Steven Antonucci
Just hammer it out?
steven antonucci
You'd be surprised at how easy it is to get it "straight enough" and how hard it is to get it truly straight. If you have a vise, you can cold set it by hand.
Steve
I agree with Steve.
robo hippy
Yup, should have used the McNaughton straight tool! Any parting job where you have to go more than about 1 inch deep.
Hind sight is %100.
robo hippy
Nah, not worth it.  I have several others.
I didn't want to sacrifice that much wood
Steven Antonucci
Cut it below the bend and make a short one?
steven antonucci
or forge it into a nice letter opener...
Nothing wrong with the steel. Give it a new purpose.
Steve
Roger
Use it as is for parting around the corner:)
Don Leydens
Don Leydens
The heck with your parting tool, Mike! That piece is spectacular. I'm not big on segmented stuff, but that piece is just gorgeous. FINALLY, someone (you) put some absolutely beautiful curves into a segmented piece. Outstanding work for sure and an eye candy piece!!
Re: Cut it below the bend and make a short one?
Mike Foster
Not a bad idea. I may just do that Steve. Thanks.
Thanks
Mike Foster
Thanks Don. This is an older piece that I completed in 2002 while in AK. I did it sort of as a tribute to the victims of 9/11. The woods are all native to the US, hence the name is All American. Looking down into it there is the references to stars and stripes.
Don Leydens
Re: Thanks
Don Leydens
You're welcome, Mike. Those are tough curves to pull off in a shape like that and they all look great together. Well done.
Don Orr
I deliberately bent a cheap parting tool and did my first core with it. No kidding-it worked on a small scale.
You should be able to straighten that out.
Steven Antonucci
so did I
