Re: I haven't yet seen the Robust sit down lathe,
Jim H
The tilt is adjustable, as well as height. The swing is 16" if I remember correctly. The headstock can slid to the end allowing you to turn off the end of the bed. It has a built in tail stock tilt away, and I believe it's 1-1/2 or 2 hp.
The supper structure of the Robust has been shifted back to give more knee room. The legs have been designed to give more clearance for a chair, and the right hand leg is made to allow most wheelchair users to roll over it.
Small details like larger handles, a tool holder that swings in from the left, and will telescope down to the end if you are working off the end of the bed and what seems to me to be perfectly balanced tail stock and tool rests to make everything easer to move from a seated position. The controls are on a pendant to be placed anywhere that works best for the user. Over all its just an incredibly well designed lathe
I will be fair in that I have not had the opportunity to sit at a Oneway sit down lathe, but have studied all of the literature, I believe the Robust is heads and tails above it.
I did get to sit in front of another (the blue one) and its just their standard lathe dropped and tilted. You can't get in close enough, and it felt very uncomfortable to me.
I have no commercial interest in the Robust, I just really, really want one ;-)
