Got a cruel lesson yesterday. The carbide tip of my new turning tool came flying off into the shavings, along with the screw, never to be seen again- -- unless my magnet finds it. I did not check the screw tight before starting to use the tool for the 3rd time. My mistake. Hope I can find both, or find a screw to fit the new cutter. Take heed fellow turners! Philip
When you find it or get a replacement, use loctite or a drop of CA. If you use CA, just a little heat will break it when the time comes. You can also use a drop under the cutter to keep it from moving, same heat trick when time to rotate.
I use Hunter tools and I don't know if that is the type of tool from which you lost your cutter and screw.
The Hunter tools use a Torx screw which when tightened down properly do not easily come loose.
Mike Hunter suggests that every time you use your Hunter before you start loosen and rotate the cutter ever so slightly so that over the course of time every bit of the edge is used multiple times until it is time for replacement.
The hardest thing for me is to know when to replace the cutter. When is it dull? Usually the chips coming off it will tell you. When I am turning end grain and I don't get long strands of curlies off the end grain that usually means the cutter is dull. If the chips come off in little pieces it is probably dull. Switching to a new cutter will confirm quickly whether the old one was dull.
Make sure the seat upon which the cutter sits is clean and free of debris when installing a new cutter.
Hope you find the carbide cutter and screw. I guess this could be compared to finding the proverbial needle in the haystack if you have loads of chips on the floor. Good luck!
Maybe a purchase of an extra screw or two woud be good. Most manufacturers sell extras. A lot of things can help to the little components; the cutters can be chipped, the screws could be lost or stripped. Always good to have an extra because if something happens to one of them, you're dead in the water. I used to have some of the popular modular tool handles. I've dropped or set screw while changing tool or had them vibrate out of the back end of the handle. When I was using these handles, I took them to the hardware store and got extra screws for every size and manufacturer. Saved me a lot of anxiety if and when I dropped one.
I'd contact the manufacturer and get an extra screw or two, and a cutter while you're at it. :-)
Don't know what kind yours is but if it is an E-Z wood, a new cutter comes with a new screw. That is from Lee Valley but I don't think that makes any difference. Could by yours does too.
When I use handles that have screws on both ends, I wrap some tape around the handle where the screws are on the unused end. That way they can't vibrate out.
Philip Was it one of the tapered head screws designed specifically for the tapered opening in the carbide cutter. I've never had one of those come loose on my EWT or my Hunter tools and even my metal lathe tools come with the same type of screw and they have never come loose.
If you were shear scraping with an action that would make the cutter spin counter clockwise I guess that could do it.
I did purchase an aftermarket small texturing tool that resembles the Sorby spiraling/texturing tool. The first time I put it to the lathe it spun in a direction that unscrewed the screw, it fell off and I never found it. Had to make my own shouldered screw to fit as a replacement. This time I added a bushing so the cutter spins on the bushing and won't unscrew the locking screw.
Thanks for all the great feedback! No luck finding either the screw or the cutter in the shavings but I still have some nooks and crannies to look thru. Researching replacements -- -ouch on the cost; $22 and 7 for a screw! What a rip. May have found a good deal but am waiting for the vendor to confirm the size of the cutter. Will post when I know.
If its a flat cutter style, try Captain Eddie, you might need to re-tap for the new screw, but for around $22 you can get 3 cutters, with screws shipped. The work just as well, if not better than the the EWT's I have. If its a Hunter tool, that's another story. They cut, differently and are probably worth the extra. I haven't had to replace one of Mike's yet so haven't looked at those prices.
And when it is time to rotate/replace, be sure and clean ALL of the gunk out of the screw socket else you'll get to practice drilling or re-buying a tool!
