Handling a large blank
Starry Chan
I have a large log measuring 22"x22". My lathe is 16". I am trying to determine what is the best way to slab this and to core it.
How would you process this big log?
Starry
Starry Chan
Starry
Re: Handling a large blank
I don't have much use for large bowls so I would probably cut it up into 4 smaller bowls or hollow vessels. If it was a spectacular piece of wood I might split it down the pith and then cut it to fit my lathe and core it. That way I would still get the big bowl but would also get some smaller ones. Most of the wood I get is pretty common and I can sell or give away smaller bowls so I simply cut up what I can. 6 to 8" bowls sell better for me, especially the flatter natural edge so If I cut shallow small natural edge shapes from a lot of the outside I could still get some bigger bowls out of the inside.
I could cut say 3" slabs from 4 sides. I could then get 2 shallow natural edge bowls from each slab. Then I would have a fairly good size square piece 22" long to try and get hollow vessels or smaller bowls from.
Or I could slice this square block into spindle stock to dry for boxes which right now are my best sellers. I could also cut some mirror blanks out of it. These are 6"x1" by however long the log is. Handle blanks are 1" square by log length.
Starry Chan
John,
Thank you for your prompt reply. How is life in retirement? You still get up quite early and checking WC postings.
I like your idea of breaking up the log into small bowl blanks. One of my original thoughts is to get 12 bowls out this ranging from 20"x10" to 6"x3". I will think about the different approaches more before proceeding to breaking it down.
BTW, the wood is magnolia, a tree with large white flowers. This wood is similar to ash. It does not check much as some other wood such as liquid amber.
Starry
I just won a small piece of Magnolia when I visited the last Chattanooga turners meeting. Looks like interesting wood. I'll have to figure out what to do with it.
Lots of "big wood issues"
steven antonucci
First, if you don't have the capacity, you kind of have no choice but to cut it down.
Secondly, if you could somehow turn it in oe big piece, you'd soon discover that big wood makes big moves. Odds are at 22", you'd end up cracked unless you made some precautions against it.
Thirdly, if you successfully turned a 22" salad bowl, you will soon learn that it is more salad than any large family could consume. My 18" bowl will hold 4 bags of lettuce and 3 containers of tomatoes from the supermarket, and it still looks empty. Unless you plan to use it for extended family gatherings, odds are it will sit on top of the cupboard like mine does.
I turned magnolia once, and it is a very nice, white, fine grained wood. My piece was only a limb, but I think bigger pieces get dark in the middle.
Steve
Barbara Gill
Why do you say Ash and Magnolia are similar?
everyone missed the best answer...
ihmserv
... buy a bigger lathe.
sorry couldn't resist.
IAN
Starry Chan
Magnolia wood color is similar to ash color in creamy white.
Both are stable wood. The end grain does not check soon after cutting. I have a few large ash logs cut a year ago and the end has not checked. If there are checks, it is not as gross as liquid amber.
The hardness is about the same judging cutting blanks with my bandsaw.
The grain tightness looks similar also from a blank. I have not turned a piece yet so I do not how Magonlia cuts comparing to ash.
Starry
Starry Chan
I am posting this to solicit ideas on breaking down this wood. There are at least two options.
The first option is to simply core out hemispherical bowls. I will have to get help from fellow turners to core the large bowls.
The second option is the break it down into smaller bowls no larger than 16". John Lucas gave me a good idea to slab it on the four sides first to get some natural edge bowl. This will reduce the diameter to about 16". I can then do the coring myself. 16" bowl is already a very large bowl. My favorite bowl size is 6" to 12".
BTW, it is not easy to mount large bowl. I think a 22"x10" blank probably weights 150 lbs or more.
Starry
