a little turning while waiting
I didn't figure I would have many visitors at my yard sale before Church was over. I am living in the Belt Buckle of the bible belt. So I thought I would try to get some work done. I make lamps from the Ballisters that were torn off our College Dorms many years ago. These are donated to fund raising efforts by the local PBS or University functions. I needed to get another one built.
It's nasty work getting the paint off. It's very abrasive and dulls tools quickly. I wear a mask and run the dust collector because I figure it's probably lead paint.
It usually takes multiple passes with the bowl gouge and quite a few sharpenings. I pulled out my EWT and the process went much faster. It did dull the tool quite a bit and I may have to rotate the cutter. It definitely doesn't cut as easily as it did when the cutter was new. I'll try the Hunter tool on the next one I turn.
I will add a small decorative ring at the top and a larger decorative base at the bottom. Sometimes I do a textured detail to add my own touch to the lamps but I think I'll just leave this one as is.
