Today, I was trying to removed the jaws from my chuck. One of the screws was stuck and it turns out the allen wrench is harder than the screw. So it has stripped.
I've soaked it in Liquid Wrench and got somewhat of a grip on it, but can't turn the screw.
How do I remove it without damaging the jaw or the chuck, especially, the chuck!
I suspect I should have cleaning ot the holes on the chuck from time to time.
Charley, I have a few things to try. First, before doing anything else get a small drift punch that will fit into the hex opening of the screw and tap the punch with a hammer smartly a couple of times to try to break up any rust, glue or other material that may be binding the screw. Second, the allen wrench may be partly stripped even if it appears okay, so grind back about 1/8-inch of the wrench very slowly so you do not heat it hot enough to draw the temper, and then try it again. If all else fails you will have to drill out the screw and remove it with a screw extractor. The last is sold in various sizes in better hardware stores and some auto supply houses. The bit that you use to drill out the screw should be smaller than the threaded hole in the chuck so that you do not damage the chuck threads.
Dennis has it, at least for the first try. Grind the allen wrench so it has good sharp square corners. Then put some medium CA on the tip, push it in as far as it will go. Then tap on it with a hammer to seat it further which hopefully will also cause the screw to change it's grip. Have patience, it will take the CA a little while to dry. Then push down as hard as you can and cross your fingers and toes. Before CA I used to use 5 minute epoxy which is actually probably stronger than the CA. You do have to find a way to hold the allen wrench still for the time it takes to harden. This has been successful for me a couple times but also failed a few so good luck.
If that doesn't work try cutting a slot in the screw head big enough for your flat blade screwdriver. Take your time and try to get square edges. Again it helps to sharpen the screwdriver before trying.
If all that fails then your down to drilling and using a screw extractor.
Charlie, if your chuck is similar to the Nova series there is an easy fix. I involves removing the offending jaw. I assume there are two screws holding the jaw to the chuck. Simply get a drill that is the same size as the head of the screw. Carefully drill the head down to the shank of the screw. then remove the other screw. Remove the jaw. There will be a short stem from the screw sticking up. You can probably turn the screw stem with a pair of pliers. Next as suggested grind off the head of the hex wrench. If it is one of the ones with a ball cut it off so the hex wrench is sharp. Darryl
To cut a slot in a flat head screw might be hard to do especially if it is countersunk even more into the jaw. I have both cases, flat and countersunk.
If you have a welder or a friend that is good at welding either tack the allen wrench in the torn screw socket or plug weld a black steel nut to the flat head screw. The nut method may not work if your screw is too close to the projecting jaw. The small amount of heat can help brake CA or char wood dust on the threads to break the hold.
Be careful on the drilling and use of an extractor as I have broken one off in the hole and then you pretty well have to weld as above when I could not drill the hardened extractor piece.
I am guilt of not cleaning out the allen head socket ever time before using the allen wrench and will someday be sorry.
I second that. I actually have a package of this somewhere before I started to do wood turning that used the same method. Now with CA glue around it's easier to do that. The most importantly, do not get into a rush.
Good luck and hope you will get it out and not damage your chuck.
If you decide to use a dremel to cut a slot make it shaped like the curved profiles they use for camera battery doors. I should have mentioned that. Then I regrind the tip of a large screwdriver to match the arc. This allows you to get a larger slot in a counter sunk screw.
When I used to do camera repair I would regrind the worn out slot in the camera battery doors and then grip a nickle in a pair of vice grips and remove the door.
I have also drilled 2 holes and used my spanner wrench but that probably won't work in your case because those screws really lock up tight in the chucks.
All of this is good advice, but if it sounds complicated or out of your league, take it to a local machine shop and ask them how much it would cost for them to get it out for you. Most of us are die hard do it yourselfers, and this may sound like heresy, but save your chuck.
Well, no luck yet. I couldn't get the CA glue to hold up. Twisted right off.
And I don't seem to have the right dremel bit to cut the screw. The bits have didn't cut my test screw.
I may just visit my local machine shop tomorrow.
Darryl - It looks like I'd only have about a sixteenth of an inch if I did what you suggested. That doesn't seem like enough to get a good grip on the screw.
I don't know a welder I trust. One neighbor has a welder on his truck but after seeing the job he did on another item for me, i wouldn't trust him with a chuck.
No one has yet suggested using a left handed drill bit. Use the same size as you would in prep for the screw extractor. With any luck, the drill bit will cause the screw to back out. If not, you will have the correct size hole for your extractor.
I thought about mentioning that but where would you find one. Locally the only ones I know about are the screw extractors that Sears sells and I'm not they are small enough.
Just after my last post, Clinton confirmed what Darryl said. Then I had a phone call from Darryl (he lives a few miles down the road) who encouraged me to use that method, as he had done it successfully himself after the method Had been recommended to him by Nova.
The bolt measured just under a 1/4" so I used a 1/4" bit. Tried to put it in my drill press but didn't have a good method of anchoring the chuck. I gave that up, put the chuck in my vise and used my cordless drill. Drilled it until I could pry the jaw away from the chuck using a screw driver for leverage. When it came off, I was able to just turn the remaining screw out by hand. Before removing it, I had a good 3/16" which would have been easy to grip with my vise grips.
There are "easy outs" made that do NOT require predrilling the bolt or screw.
I hate to recommend them but Sears (did I say I hate Sears) sells them in a pack of 3.
Thats 3 different sizes. They actually bite into the metal when they are turned the same way you would turn the screw to remove it. They look like single blade counterbore's used in woodworking to counter sink screw heads.
They are of course extremely hard.
These work much much better than the older spiral easy outs that required you drill before using them. I've had a set of these for about 10 years used them twice and they work!
I've had the odd occasion where I needed to remove frozen screws from my Nova Chucks. My problem comes from having too many chucks (6) and never switching out the jaws, and then when I need to I find that the screws are frozen.
What I do is use a drill sized to the "shank" of the screw, very carefully drill down till the head of the screw comes off, {you do not want to use a drill larger than the screw shank as otherwize you may damage the seat for the screwhead in the jaw. } Then as Darryl says you will be left with a short piece of the screw that is still protruding from the chuck body, as there is now no tension on this screw you could most likely use your fingers to remove it ... if not just use a pair of pliers.
