avoiding accidents
Keith Tompkins
In all the previous "faceshield" threads, I mentioned prevention as the best way to avoid getting hurt; imho, the face shield, which I agree should be worn, is the last resort. Here are scenario's that happen in real life that are completely preventable:
1. The turner is hollowing the inside of a bowl, the toolrest is angled to keep it close to the interior being cut. As he cuts to the center, the gouge slides off the end of the toolrest, the tool drops, contacting the wood. It is carried by the rotation of the blank,arcing around, contacting the tool rest in a dramatic fashion..crushing the turners fingers. I've seen toolrests broken (oneway) during a demo this way! Solution: Cut in the center of the toolrest whenever possible, move the toolrest so there is no chance of running off the end.
2. The turner mounts the new blank between centers, applys face shield, starts the lathe. He never checked the speed. He never knew what hit him until he woke up in the emergency room. Happens all the time. Solution: Bore a hole in the blank that partially buries the drive center. Avoid off-balance pieces if possible. Always check your speed before starting the lathe. Never stand in the line of fire. Use a faceplate for large, awkward pieces.
3. Turner mounts a blank to the lathe. He likes the grain, and the bark inclusion adds interest. As he cuts, a pleasing form is developing...until the blank explodes without warning. Solution: If the turner had studied the blank, he would have discovered the bark inclusion ran through the center of the blank, making it extremely weak. Always examine each piece before mounting on the lathe. Learn to read each piece of wood, and understand how cracks, inclusions, ring shake, etc. affect the stability of the blank. Throw away questionable wood. Like John J. says!
Can you think of a few more!?
3.
