Chat Room Problem
Dick Wilson
Ok, I still cant get on the chat.
I get a message that IE won't let me install ActyiveX control. I try and I get blocked.
Obviously I need help.
Chat Room Problem
Dick Wilson
Re: Chat Room Problem
Greg Haugen
Dick,
After seeing your message, I tried it 20 minutes after you and had no problems getting on. I don't know what ActiveX is but Java is what gets me into the chats. Check to see if you have the newest version of Java??
Not much help, I know.
Greg
Rodney
Well, first off since this is a turning forum it might not be the best place to ask a question of this type which is really a computer issue.
That being said, you would probably be more likely to get a useful answer if you gave more information. For example, it could be helpful to mention which version of Windows and IE that you are using. Also, it is best to state the exact error message you received, just saying "blocked" isn't very descriptive, it's hard to know what you mean by blocked and it could mean different things to different people. With this information someone who has the same versions and is familiar with the fix would probably step in and explain what they did.
Another way to approach the problem would be to use a search engine, Google or whichever one is your personal favorite to search with the keywords, "installing ActiveX" or use the exact error message as the keywords. Either of those methods are likely to get you several useful sites to visit with information on your specific problem.
You might find sites like the Microsoft Safety and Security Center which would explain what an ActiveX control is and warn about some dangers:
http://www.microsoft.com/security/resources/activex-whatis.aspx
Depending on your specific situation, your issue could be related to the permissions that your user has on the computer as it might be setup so that only administrative users can install something potential dangerous or it could be something as simple as the security settings on your browser (IE).
Maybe you could use the information in one of these:
http://www.ehow.com/how_5489948_manually-install-activex-browser-add.html
http://www.sevenforums.com/system-security/145610-cannot-install-active-x-control.html
http://www.sevenforums.com/tutorials/149053-internet-explorer-9-activex-filtering-turn-off.html
or even this one that is mainly aimed at ActiveX providers but also mentions how to enable the running of ActiveX controls and plug-ins.
http://forums.asp.net/t/1272937.aspx/1
If none of the above applies, try the search with the exact error message which will probably yield an explanation that fits your version.
This site (page) tests whether you have your browser properly configured to download, authenticate, install, and display ActiveX controls, and manipulate them with JavaScript.
http://www.pcpitstop.com/testax.asp
Good luck! If you still are struggling after all that, I imagine the admin will contact you and help.
Java
Assuming you have Java installed as a plug-in on your Internet Explorer (or any other) browser, you might not have it enabled. Here is a link to a quick tutorial on enabling Java.
If you don't know if you have Java installed, you can find out by going here . (This link is permanently displayed on the chatroom entry page, where it says "If you're having trouble logging in, CLICK HERE to see if you have Java installed in your browser.")
ActiveX is an application specific to Microsoft browsers if I'm not mistaken. I avoid Internet Explorer for a lot of reasons, but it does work. I just logged into the chatroom with Internet Explorer v.8 and had no trouble. I don't have version 9, but I'm sure it works or I would have heard about it by now. Active X controls -- again, if I'm not mistaken -- are a security feature that IE uses to make sure your browser doesn't run scripts that you don't trust. So, if you really want to use IE, you probably have to go into Internet Options and find the ActiveX enabling feature.
The quickest solution may be to just use Firefox or Chrome when you want to join the chatroom. If you don't have them on your computer, you can download them free from the Mozilla or Google website.
I hope this is useful.
Ellis Walentine, Host
Re: Java
Dick Wilson
THANKS EVERYONE
