The thread on band aids got me to pondering a point that has been mind since my kids got me a first aid kit for my shop years ago. Maybe some with medical back grounds can comment here.
What should we have on hand for a first aid kit in the shop? Besides band aids of course.
..lacerations is a compression bandage to stop the bleeding. Most treatments after that are simply to get whatever professional emergancy treatment is available and required for the specific incident. When discussing cardiac events or breathing difficulties there are many conflicting opinions, so keep a phone handy to dial 911, and remember the saying "to do no harm."
I keep a small plastic container with a snap on lid with the following inside:
a bottle of alcohol, a bottle of hydrogen peroxide, a big box of band aids, several clean pieces of T-shirt material to act as large compresses, Bacitracin or Neosporin, Some large gauze pads and a roll of adhesive tape.
I imagine the tape needs to be replaced because I haven't used it in many years.
I agree with Jamie that emergency communication might be one of the most important things we have as so many of us are working alone.
I always caution others to be particularly careful when turning an exotic for the first time about being alone. Very dangerous if you were to have an allergic reaction because you might not be able to talk.
I would suggest one of those pink rubber balls, about the size of a baseball.
Several years back I did something really stupid while turning and opened my wrist up real good. Just trying to call 911 was difficult while trying to apply pressure.
Probably your main pressure point going to your hands/arms is under your armpit. Putting the pink ball in your armpit and squeeze down would have been helpful in that situation. Not to say it would have stopped everything, but it would have helped.
-Craig
P.S. Someone with a greater medical background feel free to correct me if I'm talking nonsense here.
After I cut my fingers with the band saw I talked to the Doc about useing hydrogen peroxide to clean the wound. He said I should not use it. Something about killing the new skin growth.
Gosh, I have a lot of dead skin because I have been using that as one of the cleansing agents whenever I cut myself. I sure did not know that Dan.
I was taught that the initial use of hydrogen peroxide was good for helping to lift debris from wounds in which dirt may have entered. Then you are supposed to rinse with clean water followed by an antiseptic and bandage.
While there are many things that should/could be in a first aid kit the one thing that I always have in the shop with me...close by and always in the very same place is a telephone!!! Should something happen I may only have seconds/minutes to reach out for help. I need to have a phone close by living alone as I do! Vince
A common concern is sterile equipment. Sterile is good, but consider the options ----- a contaminated pair of needle nose pliers is better than bleeding to death with sterile nothing.
I have a first aid kit hanging on the wall but the best component is Johnson and Johnson Quick stop pads. These 3x3 pads stop bleeding twice as fast as regular pads. They work great and I have a box taped to the wall above my kit for fast access. Luckily I've on had to use them once.
