Favorite bandages
Favorite bandages
Favorite bandages
Craig Daymon
This is turning related, as many of us can admit.
I was cutting the nubbin off a hollowform yesterday and put the carving gouge I was using right into my thumb. (Don't worry, the prognosis is good, I'll survive.)
Overall, I definitely prefer the strips with cloth, rather than plastic straps. I'm using a cheapo grocery store brand right now. The downside being that the adhesive is not that great. The cloth is not as thick/padded as with the major brands. Between the two majors, Band-Aid and Curad, either would be a first choice for me. (Plus, when I pull a Band-Aid or Curad off, I only need 600 grit paper to clean it up. The house brands I have to start with 120. ;-) )
Preferences? Do you use duct tape and shop towels or grab for the cyanoacrylate? (I first typed cyrano acrylate, then I remember that is only good for gluing on false noses.)
-Craig
Re: Favorite bandages
Paper towels and blue painters tape. I always have that around.
Mike Stafford
Mike Stafford
I hope Jamie doesn't read this. I was using his carving gouge in his class on square turning and managed to cut my thumb so severely I had to get stitches.
Now whenever I show up at John C. Campbell students bring band aids. My dear friend Ed Moore threatened to rent the emergency squad ambulance the first day of class just in case.
To answer your question I prefer the cloth strips with Spongebob Squarepants on them like Carol Reed brought to class. See photo below.
Don't do that Craig! Be careful out there!
Wayne Kuhn
I whacked my thumb with a hammer and it caught the edge of a casting. Nasty cut, peeled a good bit of my thumb back, but no blunt force injury. My treatment program is to soak in hydrogen peroxide, a little neosporin, bandaid. I try to do this once daily. This happened 2 Sundays ago and I was back at the lathe this past Sunday. exactly one week. Neosporin is one of the best antibiotic pain relief creams out there, I swear by it. But as usual, ymmv. Good luck.
Oh BTW I prefer bandaid fabric brand.
Stafford is lucky to get Spongebob
Greg Haugen
Favorite bandaids?? Well I buy my own for the shop because with three daughters, I wouldn't be as lucky as Stafford to get Spongebob, I would end up with "Hello Kitty," "Tinkerbell," or "Dora" if I used the "house" bandages.
I do prefer either fabric or the athletic type that's more like sponge/foam (it's not fabric or plastic). But as far as course of action? Could be CA, paper towel and tape, but usually a bandaid is last. Just easier to wrap and tape or glue it shut but there is a pack of bandages in the shop.
Harry Robinette
Harry Robinette
I use latex free bandages from Discount Drug Mart. They stick to anything but will release cleanly if you keep a slow steady pull.
Last year I cut the tip off my little finger on the band saw (using the wrong blade to cut a green wet wood blank.) I was the only one home so it was stick it back on and band aided it back on till I could get some place for help. The blood stopped almost immediately so I finished the blank put it on the lathe and turned it.
By the way the LOML flipped out about not going to the hospital, bet non of you have had that happen.
George Taylor
Hello Kitty was the bandaid of choice ...
George Taylor
... at Mike's class this past June. They did come into use (although Mike played it safe).
I bet Jamie (or Joe Johnson) will certainly respond now. :D :D
3M Nexcare
Ray - temp in LV, NV
Pricey but they are clear and super thin with a large cloth pad. Conforms to every wrinkle, that is if you are old enough to have wrinkles. Completely waterproof and can be worn for multiple days. Sorry, no Sponge Bob printing.
Ray
robo hippy
It seems like I end up with some thing different every time, though I have some Band Aid Flexible Fabric ones right now, and they stretch to fit and stick pretty well. Nicked my left index finger (just took the callus off), right where I use it for playing the guitar. The band aid was flexible enough so I could still try to play some leads, and it fit well over one of these spots that is too round for a normal band aid to stick. A little neosporin, and a couple of days, and almost back to new. I have used all of the above at one time or another, but did have Scooby Doo rather than Sponge Bob.
robo hippy
mjonesrdg
Craig, thinking about cyrano acrylate for noses had me rolling...I'll think about that every time I bandage a cut! (whoops, I think you slipped one by some of the others here! :D :D )
Joe Bradshaw
Re: Hello Kitty was the bandaid of choice ...
Joe Bradshaw
George, I am going to plead the 5th on the bandaids.
Mike Stafford
Not much funnier.....
Mike Stafford
than a tattooed retired Navy seal diver wearing a couple of Hello Kitty bandaids on a fist the size of a cantaloupe. If the band-aid fits, wear it!
Just saying, Joe. :b :D
RCH
The most recent nick in the shop got paper towel and blue tape. I got very accustomed to small cuts in the years I did stained glass work -- glass makes the finest tool edge feel blunt. As for the house supply of the 'real thing', whatever was available when I last thought to buy a supply.
I like the fabric ones made for fingers. They are a lot longer and the pad is offset to one end so the "strap" on one is about three times as long as the shorter side. I would look at the box and tell you the exact name and brand, but my son discovered the box and apparently they were more important to him than to me. They are available in both name brands and store brands. the longer piece of tape is really good for wrapping them all the way around the finger and they are flexible. I have been known to trim them down in width and even make them hour glass shaped to make any band aide fit better.
There is one of those TV commercials for some kind of drug that says "Don't start ***** if you have a cut or infection." I won't be able to use that. I can't remember not having a cut.
Under the bandage, my favorite thing,
Keith Newton
Is to cut a nice ~1" plump slice of Aloe from a healthy leaf. Then slit it and tape it over the cut before going to bed. By morning, most things will be healed. It seems to have just what new cells need to grow.
Don Leydens
Don Leydens
Mike, my "Hello Kitty" bandages I brought to your Campbell class weren't good enough?
Excellent thread!
Molly Winton
Nothin' ticks me off more than injuring myself in the middle of a project. I hate getting blood all over my piece, and it's really inconvenient to break my stride in order to clean and bandage myself. Did something stupid last week (I'm not tellin'!) which necessitated first aid. I like the flexible cloth bandaids, but sometimes I'll dress them up by putting an Angry Bird or Muppets bandaid over the top of them. I like bling.
I tried showing as much restraint as........
JamieDonaldson
...possible while following this thread, but now.......!!?? My squad in Vietnam (circa 1968) must have been among the first to be issued CA in our first aid field kits, and shortly thereafter I was a user of same. During an ambush I rolled onto a punji stake that puctured my R calf, and when things quieted down our squad medic sealed the wound with CA. The glue made the pressure bandage a permanent part of my leg for more than a week, so when we returned to base camp I was OK to go. Found out more than a year later that a piece of the bamboo was still in my leg, but I won't bore y'all with those details. The point of this convoluted story is to not apply just any bandaid of any type over a glob of CA glue unless you want to wear it for a while. Pick out a happy face bandaid that appeals to you because it might become very attached to you for an indeterminate period of time!
Mike Stafford
I like to color the plain band-aids....
Mike Stafford
I like to color the plain band-aids, Molly. :b
Seems like a couple of nice ladies gave me a bunch of crayons a while back. :D
I really prefer the cloth band-aids and the Band-aid company sells a package with lots of specialized sizes and shapes for dealing with hand nicks and cuts. They seem to adhere well also.
Mike Stafford
Mike Stafford
Be careful about what you say Mr. Leydens. I will inadvertently let slip that you had to use a 3" long band-aid when you nicked your leg with a gouge and it wrapped around twice..... :b
Steven Antonucci
The practicality of 4 kids
steven antonucci
We are never out of bandaids, but I did get tired of Power Rangers, Sponge Bob and Barbie, so I picked up a $1 box last time I was out. They are no name, el cheap-o plastic ones, but they do keep the blood off of the piece.
It has been a long time since I did anything that required more than a little bandaid, but I have paper towels and duct tape in the garage as a back-up. I used CA glue once, and well... the cure is worse than the condition.
Given a real injury, I do prefer cloth bandaids for their flexibility, but they cost more than $1.
Steve
First rule of the shop: Knives cut meat, and you never put anything you don't want to cut in front of them. You are made out of meat.
Actually Steve, I found out the CA.....
JamieDonaldson
...doesn't hurt nearly as much as the activator! Yyyeaaoo!! >( :b
Leo Cuellar
Re: My favorite is a
Leo Cuellar
piece of gauze wrapped with electrical tape. I keep several colors of tape because I like to be color coordinated :D
Mike Stafford
Color coordinated, I like it!
Mike Stafford
:D :D :D
Re: Excellent thread!
Craig Daymon
Usually I don't notice the cut until I spot some color on the workpiece. Then I typically end up rubbing the spot with the bloody finger and suddenly I realize where it came from.
Sad part of the recent incident is that I had just bought a carving glove about a week before, but hadn't put it on.
