Work in progress: turned spoons
Leo Cuellar
Leo Cuellar
No carbide was harmed in the making of these items. :D
But, I'll have to try it next time!
I'm still working out some of the mechanics on these yet. I wanted to see how close I could get to a working spoon using mostly the lathe. The bowl of the spoon is hollowed on 3 centers gripping the stock in Terry Scott's favored two jaw grip, with my daffy counterweighted chuck. It took a while to figure how deep & what slope to use to match the outside. After that it is mounted between centers to turn the handle round & cut beads. Then it is mounted offset to the extreme edge of the stock. I had to glue on small blocks to the top after roughing the bowl to keep enough strength at the ends to keep the blank from flying off the lathe.
The major size/length limiting factor is the swing of your lathe. The bowl needs to be power or hand sanded as, if you don't have an oval chuck, you aren't going to get a smooth bowl from turning alone. Although, a round bowl would probably look good too. The farther from the center that you can offset the blank makes for a shallower curve... I'm going to have to figure out an adjustable center for the chuck.
Oh, it is about 1" thick and 8 & 1/2" long, in Birch.
C & C is always welcome. Have a great day everybody!
Re: Work in progress: turned spoons
Steven Antonucci
Please show the Oval grip?
steven antonucci
Cool, but not obvious to me. I'd love to see it
Steve
Don Leydens
Re: Please show the Oval grip?
Don Leydens
Great job Leo. Lots of work and figuring out to make what most people
would consider a simple item. Not so simple, really. Excellent work!
Leo Cuellar
Yah, sure ya betcha.
Leo Cuellar
Sure thing, Steve.
So first off, you want to decide what kind of shape you want the bowl of your spoon to have. It could be round or bigger at the front or the back. You might want it more of an oval shape. Check out the top three items in the poor sketch.
I would suggest marking the circles darkly to aid in cutting, I used the slice & stop method :\
The third one depicts that it may be possible to make a heart shape if you attach the blank to a narrower block with screws or hot melt glue and then move it laterally in addition to up & down from the center of the chuck. ( Only a hypothesis at this point.)
The bottom two show where to mount between centers for the round & offset points.
Then to get your "ovalness" slide the blank to coincide with your first circle, cut it, then go to the far end of your intended cutout & repeat. After that one split the difference & take out as much wood as you need to get at much of your interior removed as you can. Expect the same kind of feel as cutting into something with a void.
Of course the farther away from the centerline that you get the flatter your curve will be. I didn't think about attaching to a full size block before doing this, but this seems to be plenty strong with Titebond.
Then after you finish doing up the handle, you carve & or sand out the bowl to your liking. :) Let me know if you still have Q's. Not sure if what I know is worth sharing, but always willing. :D
Steven Antonucci
Interesting, but not what I thought
steven antonucci
I sort of expected that you had some kind of long tube with the blank mounted inside, and that you treated it like a hollowing exercise. I usually hand carve mine after turning, and you get the "perfect outside" with the "less than perfect" bowls... drives me nuts.
Thanks for posting.
Steve
Leo Cuellar
I think I get what you mean...
Leo Cuellar
and have been thinking about how I would do a dipper or ladle shape, but haven't had time to give it serious thought. Maybe tonight while I'm at work... :D
Mike Stafford
Looking good Leo!
Mike Stafford
I would be happy to use one of these spoons for my gruel.
Steven Antonucci
Check out Michael Hosaluk for ladles
