Do you like this one better
Terry Scott
I made this piece and decided it needed a stand of sorts so that with the negative positive spaces shadow was caste beyond the work onto a wall or surface.
I played around for months and a dozen or more stands ranging from burls to boards even sea shells .
Then one day I picked up this antler and lo and behold the work just sat there .I have airbrushed the antler as it was a bit harsh looking against the brown mallee
Turned with my support ring process (lets say very thin as you can flex like a Rolf Harris Womfa (iron sheet that he uses to create music)
If you are flying out of Auckland airport in the next month have a look in Art port as it is on display and sale in their front window.
Over the years Ive built boats and even laid stone walls so I have developed an eye when looking at thinks to see if they will fit hard to explain but if you have been in similar trades you will understand how easy it becomes to scribe one odd shape into another without using a ruler and eyeballing it.This Mallee went through 20 or more Dremel bits even the carbide ones.
I prefer the leaves to be Terry Scott a bit rough and ready as sometimes I see work that is almost clinical.(thats my excuse and I am sticking to it
Cheers
Re: Do you like this one better
Dale Jablonski
Dale Jablonski
Everything I've seen that you've posted can be summed up by one word. Magnificent!
phillip medghalchi
Terry, you did a beautiful job on this. even your air brushed antler seems to belong right along there with it. I was wondering that you said you turned the piece very thin, that how you managed it not to break it so many times? And, BTW, what's the final thickness of the piece?
Don Leydens
Don Leydens
First impressions are everything and when I fist saw this I thought... "ohhhhh, wooooow. Still stands. Terrific work, Terry!!
