Perception - One At A Time
charlie belden
Playing in a visual medium, I've had an interest in how we perceive what we see. From light reflected off an object that reaches receptors in our two eyes, to what gets sent down the optic nerve - and then what the rest of our brain does with that information before we perceive what the final information means is really quite interesting. With a basic understanding of that process, one can create images (and objects) that exploit the visual process and processing.
A classic example of expoiting the visual system is the Wire Frame Box - viewed from above and seen "looking DOWN into it ", then a fraction of a second later, viewed from below and seen "looking UP into it". Only one perception can be "seen" at a time and the preception can switch back and forth, though may require some conscious effort to make that swtich.
Here's another example I stumbled on while playing with SketchUp. One perception is that of a continuous ribbon with six loops, inside a circle. The other perception is six flat washers, one on each face of a cube. With that in mind, look at the gray scale version and try and swtich back and forth between the two perceptions.
Seems this One Or The Other could be exploited with pyrography on a piece.
Have YOU other examples of this See A OR B, But Not BOTH phenomenon?
