end grain or pithy wood
Lewis Dodd
Doing some elm wood bowls and the end grain is driving me nutso...Any products recommended to fill the Plucking, pithy spots on the end grain sides oif the bowls..any techniques to help me out? I have tried CA glue and Sand and sealer...
Thanks
Lewis
Re: end grain or pithy wood
New Wood Term
"Plucky", but if you've got punky wood, the only thing I've found useful is saturating the wood with epoxy resin to replace the lignin eaten by the rot. Wood must be very dry for the attempt. Absent that, pitch it in the burn pile and get some sound good wood to turn ["Life's Too Short . . ."]. After all, the stuff does grow on trees ;)
Lewis,
GaryG in MD
If you're working with sound wood and having trouble with tearout in the end grain, it's a very common problem.
The solutions to this problem are:
1)sharp tools
2) correct tools for the task
3)sharp tools
4) proper tool technique for the given tool
5) sharp tools
6) firming up the end grain with water or shellac
7) sharp tools
You don't want to sand the tear out away later -- you want to eliminate (or strictly limit it) in your final cuts. Always sharpen your tool immediately before making the final cuts. Final cuts should be extremely light -- only "whiskers" should be coming off your tool. Consider shear scraping if on the outside. Consider a negative-rake "bowl scraper" if on the inside. But scraping can make the situation worse. Depends on the situation. For the inside of an end-grain bowl, consider using a Hunter cutter. They're sweet.
It all depends on the wood. Sometimes dealing with end-grain tear out is easier said than done, but that's my story, and I'm sticking to it!
...Gary
