Re: Rethinking The Priddle Wood Vaporizer
Graeme Priddle
Good morning all:) Graeme here.
Ellis gave me the heads up that there was some woodburner discussion going on so I thought I'd put in my 2c's worth.
Howzit Michael, the foredom pedal is a great idea!!!!
Charlie, as Denis mentioned you'd need a switch capable of carrying at least 10-15 amps on the 12v side and there could be arcing problems which you would need a hefty capacitor to overcome and it would all probably be pretty cumbersome. Control on the 110v side is much easier and cheaper.
It's not something I would consider as I want my tip to be glowing orange hot all the time so I can work faster, if you are switching off and on between brands there is a heat recovery time that will slow down working time.
In the 10 years I have been playing with woodburners the handpieces are the biggest problem, most get way too hot to handle with constant use and I have been through a lot of trial and error development to get to a easy to use handpiece that doesn't get too hot. The one I am making now seems good, still gets pretty warm but not to an uncomfortable level. I've made and sold a bunch of these over the last coupla years and haven't had any negative feedback yet:)
On another note for those that are interested in building a burner the NAPA 85-220 battery charger I have favoured in the past has been discontinued by NAPA:(:( but the 85-437 works fine but you gotta rip out all the electronic bits and it costs a bit more but still cheaper than commercial units and way more bang for your buck:)
Will try and keep an eye on this thread but on the road in France right now so if you need any more info you can e me direct at graemepriddle@xtra.co.nz
Happy burning!
Cheers
Graeme
