Bowl Instruction Sheet
phillip medghalchi
In an effort not to hijack other thread, I am writing this thread to discuss my concern.
Under the main thread "Bill Turpin in WNC mountains -- 9/5/2012" wrote that he prints this and gives it to the customers:
"This bowl is a great utensil; use it to serve pasta, salad, fruit, and popcorn. After use, just hand wash with warm water and soap, then wipe dry, and let it finish drying in open air. Please do not soak it in water, or put it into the dishwasher or microwave. If it seems to be a little rough, use a half lemon to scrub a teaspoon of salt around in the bowl. It will smooth it, and purify it at the same time. Occasionally recondition the bowl with walnut oil or mineral oil. With proper care, it will last for generations... making this bowl a family heirloom. Please share it with the next generation of food lovers!"
I was under the impression that we should not use the pure kitchen walnut oil on the wooden bowls since they will go rancid and would create problem down the road. the walnut oil finish we apply as a finish it's specifically formulated as such to eliminate this problem. So, shouldn't Bill give them or sell them the walnut oil he applied to the bowl, to possibly avoid this from happening?
Re: Bowl Instruction Sheet
Steven Antonucci
Walnut oil cures.  Mineral oil doesn't go rancid.
Re: Walnut oil cures.  Mineral oil doesn't go ranc
Chuck Engstrom
Hi folks -- I have seen at least one grocery-store walnut oil that listed an ingredient specifically as a preservative along with the walnut oil itself (can't remember the name) and I expect that it would prevent an effective cure of the sort turners are hoping for. Mahoney's strikes me as pretty slow to cure, even given generous sunlight to provide the UV that (I once read) drives the cure of walnut oil. Check the ingredients if you're trying something else, and let us know how it all works out.
Best -- Chuck
Phillip I'm certainly no expert here. I have my finishes that I play with. Walnut oil being one of them. I think Walnut oils harden, both the store bought and Mahoney's. The difference if I'm correct is that Mahoney's has had additional work done to it to remove the possible nut alergy qualities. At least that's the way I understand it.
The two things I look for in a user bowl finish is appearance while I'm selling it, and longevity, and yes I should include repairability since you might get it back at some date to rejuvinate the finish.
Many finishes will look good when your selling it. Finishes that "build" will look terrible after 6 months of use. Consequently I want a penetrating finish such as an oil. I also don't want the oil to go bad so that seems to leave Mineral oil and Walnut oil as the best alternatives. Some use a Beeswax and oil mixture but I would have to try and find that because I've forgotten what it is.
The wipe on finishes like Minwax and Watco seem to look pretty good and last a while but don't think the average consumer will have that laying around to refinish if the bowl starts to look worn. Again that goes back to the Walnut or mineral oils because it's easy for a customer to aquire.
I'm like you I'm still looking. What seems to make the biggest difference it before the finish or as Russ used to say "finish it before you finish it". I sand to a higher grit when I use the pure oil finishes. That seems to do two things. First it takes less finish. The finish doesn't seem to soak into end grain areas as bad so it takes fewer coats, and second it simply looks nicer.
Phillip: all my customers are told that the bowl is finished with walnut oil. I prefer to not have un-cured petroleum products on food containers. If they have nut problems they will not use nut oils to perk the bowl up. The real problems show up with microwaves and soaking sinks.
Jim Breeden
Phillip: I use Mahoney's walnut oil on all my salad bowls and platters. I soak my work until it can't hold anymore, then turn on the lathe to 2,000RPM and "burn" it in. Finished a walnut bisquit bowl for my wife today, and the oil has already hardened to a gloss with the burn-in. I do not use mineral oil, as it remains soft and does not give me what I'm looking for. Hope this helps.
Richard Jones
Further to what Jim said, I have recently "discovered" that if I allow the walnut oil (I buy La Tourangelle Roasted Walnut Oil) to dry at least 2-3 days in direct/indirect sunlight and then lightly "buff" with some 600 or 800 grit paper, it really brings out a nice, even, satin sheen, better than actually buffing it with the standard stuff. Also smoothes out any grain-raised areas caused by the oil.
I don't use any wax with walnut oil, but do use it with DO.
Rich
robo hippy
Well, the Doc did a demo for our club, and since he is from Oregon, I now use his oil instead of Mike's. No other reason really. He was able to dumb things down enough so we could understand, but I forgot most of it.
http://www.doctorswoodshop.com/
robo hippy
phillip medghalchi
Richard apprecaite your input, however, what is DO? upi mentioned it in your post?
phillip medghalchi
Jim, thank you for your post, I am not sure if I know what "burning" is in your explanation, I'd appreciate it if you could email me with the direction or whre I can read up on it, If you do not wish to repeat it in this thread. Again, I am the newbie here that's why.
Jim Breeden
Phillip: I am also the newbie here. By burning in I mean, put as much walnut oil on the piece as it can soak in, turn up the lathe to 2,000rpm, add some oil to a cotton rag and, while the lathe is spinning, hold the rag against the piece until you can't stand the heat any longer. This will force the oil into the wood and will become hard and glossy. I normally us a pair of gloves for this step, or you won't be able to hold the rag against it very long. It usually only takes about a minute or less to accomplish the "burn-in".
Also, I believe my ears are burning from the old timers :D here who are saying, "WHAT"?.
phillip medghalchi
Jim, I may be wrong , but I don't think that's called "burning", then again what do I know. however, I get the method now and thanks for the tip. BTW, which Oregon club is this. I was at the east portland meeting on June 23Th of this year, the one that Dale Larson attends also. I wonder if you were there too?
Jim Breeden
Nope, twern't me, last time I was in Oregon was three years ago. I didn't know what to call it when the oil got hot, so I just named it burn-in. Probably a misnomer :) on my part.
phillip medghalchi
I am hoping that one the experts here will correct both of us about this before we embarrass ourselves.
Jim Breeden
I think I'm already embarassed, emphisis. I can see 'em now . . . :D
