Bloodwood pic help
Jim Evans
I am no photographer as you can see. I took the picture outdoors and should have used a different color back ground or different camera settings.
My camera is a cheap vivitar.
Help for and old fat guy.
Bloodwood pic help
Jim Evans
Re: Bloodwood pic help
You shot it outdoors in the shade. That will often make a back ground go blue. If your camera has an outdoor shade white balance setting use that. Sometimes green trees will also shift the color toward the green side but I don't see that in this image. If you don't have the shady white balance setting you will have to correct the color in whatever program you use to size the image if it has color correction capabilities.
As far as the high gloss reflection on the sides, good luck. No seriously it is very difficult to get rid of these. You have to go to a black back ground or sometimes you can use black cards just out of the image area to reflect into the sides. However this messes with your camera settings big time so unless your willing to go to manual settings and manually adjust the camera don't use a black back ground. A neutral gray will work the best but it shows up the color shifts the worse.
I tried to correct the color to a gray background assuming that is what you used. There are green shadows so the trees did affect the color. If you didn't use a gray background then the color of the piece will be off in this photo.
Don Evans
I cannot tell if camera shake is causing any of the several problems but one trick to use if you dont have an excellent tripod is to:
set camera on books or something to support it and use the self timer on the camera, set it for say 10 seconds, then carefully press the shutter button and remove hand, let the camera shoot at the end of the 10 seconds. I use this even with a tripod.
I hate the fact that not even my Nikon D60 has a shutter button that you can screw in a cable! why I wonder? It has a built in remote but they designed it for IR light so you have to be in FRONT of the camera for it to work, what were they thinking or NOT thinking I wonder.
Don
Jim Evans
Thanks John. Your color of the mill is dead on so I'll try the daylight settings tomorrow. I also have an old Olympus that I might be able to get running.
Jim Evans
Don, I think you are right on the shaky blur. I have a decent tripod that I should have used.
Jim Evans
John, I tried the outdoor setting and used a different subject and I think it may look a little better. The background is actually white and I don't know which setting I should have used to make it white instead of blue. I am very photo challenged.
Doc Green
Jim, I think a contributing factor in the color mismatch is underexposure. My suggestion is to increase the exposure by about 0.7 or 1 stop. This may cause the background to go completely white, but it probably will give a better color balance in the subject.
Another suggestion is to try a light gray background instead of pure white so the background doesn't overpower the exposure controls of the camera.
Keep the faith. Once you find a solution, the problem will seem simple. ~Doc
