I was at the beach a couple of weekends ago and went in a sea shell shop and saw this slice of a conch shell. I though it might make a good finial for a box so I got a couple. I turned a cedar box and drilled an off center hole in the top and inserted a piece of ebony in it. Then I inserted the slice of conch shell in the ebony upside so one side was roughly vertical with the center of the box. This is my first try as something like this so any comments and suggestions are welcome. I still haven't got a photo box set up. I'm working on that. This was taken outside with avaliable light.
I put a coat of Minwax Antique Oil on the inside but, didn't buff it so you can still smell the cedar a little bit. I wish I had left the inside natural so you could smell the cedar better. I guess I will just have to do another one.
This Dude is on a roll! Sweet box Bob. I like the shell, the form and the wood, although the ebony throws me off a tiny bit. That's just me. Lovely piece of work. Keep it up!!
Beautiful piece, nice form. The finial when set in the offset ebony looks to me like a sailboat approaching the top of the world. I think if you would not have offset the ebony the finial wouldn't look as nice as it does.
Those are very original touches, Bob, and they make for a very compelling and unexpected design. I took the liberty of straightening, sharpening and darkening your image a bit; see if you like it. One thing to remember about automatic exposures is that camera meters are calibrated to medium gray, so they tend to overexpose the image if the meter is concentrating on a dark part of the scene. If you can't preview the image, it pays to bracket your exposures on the darker side, say -1 and -2 stops, then pick the best one.
As for the interior finish, this little box is like a cedar chest: if you want the aroma of the wood to stick around, you really can't finish it at all, as any film, even wax, will lock in the aroma. The good news is that juniper and yew take a really beautiful polish if you're willing to sand to a high grit, say 600 or more. It almost gives the illusion of a finish.
I'm also curious as to whether you went for a light slip fit on the lid, so that it can be easily removed by picking up the shell finial? That would seem to make sense to me.
Ellis, Thanks for enhancing my photo. I'm new to these photo techniques. I think what you did was quite an improvement. I didn't think about leaving the inside unfinished in time. I should have done that. I guess I will just have to make another cedar box. :-) I did make the lid a light slip fit so that the shell wouldn't come out when you removed the lid. It is glued in with medium CA. Thanks for the suggestions and comments.
