Running again
Steven Antonucci
So, with the saw not being operational and neding to cut, I took it apart moreso than I ever have in the past... learned a few things.
The brake is a steel band under a lot of tension. It wraps around a metal flywheel until the brake it tripped. The flywheel is the thing right behind the chain sprocket.
No amount of leverage from any angle would let me reset the brake. I had intended to reset it, and just repeat the process if it was tripped. The brake handle was broken in the "pull back direction"... but I am certain that it would have "kicked forward" to trip if I had gotten a kickback. To no avail, it couldn't be reset... so I took out the steel band that wraps the flywheel. The saw now has no brake until I can get it fixed.
I am aware of the cutting risks if you use a chainsaw improperly. Personally, I think the chainsaw is about the easiest and safest tool a woodturner has in his/her arsenal if used properly. The anti kickback pawls keep the saw in the wood, and you are only making one cut. I would not do field work with it without a brake.
Lastly, if you have never pulled the cover off of your saw (behind the bar), you probably should. I didn't even know it was there, but in trying to reset the brake, it partially opened. I took it off and the entire inside was filled with "mud". It was a combination of decayed sawdust, oil and who knows what else... I cleaned it out with a screw driver and some compressed air. I will now check it every time I tune my saw.
Steve
