Analine dye troubles
Don in Central Illinois
Turned a small cherry bowl, sanded, etc. Add red analine dye, brushed on with sponge brush. Part of it has a definite greenish cast. Haven't had that happen before and am extremely confused. Any ideas about why this happened? Thanks in advance.
Re: Analine dye troubles
John Veerkamp
Maybe the cherry wasn't ripe yet? Sorry about that. I' speculating that there was some type of chemical reaction between the dye solvent and chemicals in the wood. Was the cherry dry or was there still some moisture in it?
Dick Coers
Red and yellow should make orange. Did you mix the dye yourself from powder, or liquid? If you mixed it, did you use distilled water? Mix with alcohol? More details about the dye please.
Harvested in January, rough turned in January put in plastic bags turnrd inside out every few days. Finished turned last week, so I believe it is fairly dry.
Mixed myself with distilled water from powder, although it has been quite awhile ago. Used it right after I mixed it and it worked fine. Maybe it has degraded over time.
Bill Howatt
I believe the LV packages or somebody cautions about the storage life such that it should only be mixed as needed.
Bill
stored in glass or plastic?
Dick Coers
Plastic will let oxygen in, and can't be good for the dye.
Re: stored in glass or plastic?
Plasrltic. Will try it on a bowl that is beyond repair and see if itvacts the same. Thanks all for the help.
I had water bases analine dye mixed up in plastic bottles for many years and it always seemed to work perfectly. I finally got rid of it when I bought the metalized dyes. I gave it to another club member who is still using it so if the stuff goes bad it sure takes a while.
Are the metallic dyes more vibrant? I know the metallic prints I used at the photo studio wete very different from ordinsry prints.
Not that I can tell. The reason I changed was they are more archival and I don't want my work fading over the years.
Ray - Middletown, in
I think the key to this is "quite a while". Red is the least stable color and may have gone bad. It is the one I have the most trouble with in trying to store for an extended period.
Ray
